right turn signal
Actually, a bulb is burned out or a socket is corroded on the side that doesn't flash. Put on your hazard flashers and walk around the car looking for the bulb that doesn't flash then replace the bulb and/or clean the socket.
Now it is possible that the mere act of replacing the bulb will rub off enough corrosion in the socket to make a non-working bulb start working. But that would happen even if you just removed the bulb, wiped it off, and put it back in. That could explain what you saw when it happened to you.
