New Kit for the Birds
Old Jun 12, 2010 | 10:18 PM
  #61
reelnauti's Avatar
I have ordered low beams and fogs. One of the best things I have done. Great bang for your buck. Just find the bulb your camaro uses and order it. You can also go here for info http://www.hidplanet.com/
Old Jun 17, 2010 | 04:01 PM
  #62
bearcatt's Avatar
Ok so I installed my LMC housings without HIDs, I decided to go a different direction. Ended up using Toshiba HIR 9006 and 9007 bulbs.
These are not quite as bright as HIDs but they are a vast improvement over the stock 4701 and 4703 sealed beams and/or other typical 9006, 9007 bulbs with sealed beam conversions.
Comparison between the HIR bulb vs other 9006 bulbs.
Standard 9006 halogen (low beam): 1000 lumens, 800 hour rated life
Sylvania 9006 Xtravision (low beam): 1060 lumens, 300 hour rated life
GE 9006 Nighthawk (low beam): 1150 lumens, 250 hour rated life
Toshiba HIR 9006 (low beam): 1800 lumens, 800 hour rated life
Sylvania 9006 Silverstar (low beam): 910 lumens, 150 hour rated life
A brief description on how they work.
"HIR" - halogen infrared reflecting. They work by reflecting the invisible infrared rays that all halogen bulbs produce back into the filament, making it burn brighter than a regular bulb.
A brief story about these bulbs.
From what I understand these were initially designed by GE for John Deer and are now licensed to Toshiba.
I also ended up installing a relay harness wired directly to the battery post next to the fuse box within the driverside engine compartment.
Also in order for the bulbs to fit, it was required to cut a good amount from the headlight buckets. ( shown in the pictures below ).
The Sony camera I used isn't doing much justice for these pictures and video clip below. They are much whiter in real life.
( Perhaps it's my camera settings ).
Small video clip from my trip to Texas on the first week of June 2010.
( Highbeams and foglights turned on ).
http://www.garagedooropeners.us/240s...ts_driving.MPG
Low Beams
High Beams
Wiring harness relays
Wiring harness routing
Left buckets
Right buckets
Actual HIR bulb
Here's some better before and after shots from a Saturn website.
Old Jun 28, 2010 | 12:42 PM
  #63
ERL_'s Avatar
alright soo, for the fogs we can just order some hids and plug them right into the stock fog light housing?
Old Jun 28, 2010 | 03:29 PM
  #64
Danny2tek's Avatar
That's correct
Old Jul 2, 2010 | 07:29 PM
  #65
ERL_'s Avatar
got the ddmt bulbs today, just waiting on the lmc housing. i wanted to get the fogs in today. could someone tell me how they were able to get to the fog lights to change the bulbs, and also ,how and where they mounted their ballasts. thanx!
Old Jul 6, 2010 | 08:10 PM
  #66
got milk??'s Avatar
As far as cheap good quality HIDs I have been using 9006 Slim HIDs they can be found on EBAY. They have been in my Acura Integra for over 2 years with no problems. I use the 9006 in all 4 of my rides. They can be found for less than 60 bucks just a thought before you go spending 130 bucks on "Higher quality HIDS" Unless you spend the 500 bones on a real set of HIDs or steal them off a C6 Vette your getting the cheaper quality stuff anyway.
Old Jul 9, 2010 | 07:52 PM
  #67
firebirdmo's Avatar
I did the same as stanger too.. I just put some nice HID and have been blinding everything in front and on the sides of my bird. Next is the HID, but regardless the upgrades our lights on these cars seem to upgrade on a regular to something better and brighter... I say do the HID's.
Old Jul 20, 2010 | 12:39 AM
  #68
Zeke34's Avatar
Hey guys, I've been looking at various threads on here and just wanted to make sure that I'm thinking in the right direction before I order an HID kit. My plan is to use the LMC headlights (36-0302 & 36-0303), now I know that for the lowbeam headlights I'd need to use 9006 bulbs but what about the highs?
Old Jul 30, 2010 | 07:31 PM
  #69
reelnauti's Avatar
I just left the highs with the bulb that came from lmc cause hid do not like to be flashed.
Old Jul 31, 2010 | 03:56 PM
  #70
Danny2tek's Avatar
^ same here.... the funny part is when I turn on the high's there's hardly any difference.
Old Aug 1, 2010 | 05:01 PM
  #71
Zeke34's Avatar
Interesting... Thanks for the info guys...
Old Aug 7, 2010 | 09:37 PM
  #72
TAvsGN's Avatar
I have been wanting to do the HID conversion, just waiting for the cash. If I stay with the 35w HID bulbs in the fogs and lows, I don't have to get the extra wiring harness that is advertised? I was also thinking of doing the LMC housings and staying with the highbeam bulb they provide, no HID. Do I need the extra harness for those? They looked like 55w bulbs, unless I read it wrong.
Old Aug 8, 2010 | 05:22 PM
  #73
Danny2tek's Avatar
Im running 35 watts in the lows and the fogs with no optional relay/harness. And for the the highs I kept the bulb that came with LMC's. Remember HID's dont like to be flashed on/off, thats why I didnt put them in the highs
Old Aug 9, 2010 | 08:59 PM
  #74
t/a98's Avatar
Maybe I'm stupid... But why/who cares what the Hid's like when they have a lifetime warranty, even if they didn't, it's like 15 bucks for two bulbs, cheaper than halogens...
Old Aug 14, 2010 | 02:10 PM
  #75
blackls1ta00's Avatar
just ordered the lmc housings and ddmt hids lows and fogs with 35 watt 6000k temp,cant wait to install them,thanks for info guys.
Old Aug 18, 2010 | 02:07 AM
  #76
LOTTI99TA's Avatar
Default help with link to LMC for the housings
It's probably user error but i cant seem to locate the housing on the LMCTRUCK site. Can someone give me an updated link or something. all it gives me is diffrent choices of trucks (duh) but which model and year. It doesn't want to let me go to a list of headlight housings. I'm trying to upgrade headlights and fogs on a 99TA.. Anything user friendly would help.
Old Aug 18, 2010 | 09:36 AM
  #77
VIP1's Avatar
Copy & Paste Moderator
I did some quick searching on Google and their website. It looks like its on page 65 of their "1988-1998 Chevrolet and GMC Truck" catalog. "150mm headlight". They are labeled as Inner/Outer instead of High/Low. Inner should be High and Outer should be Low.
Can those who bought it confirm that it is the one they bought?
Old Aug 18, 2010 | 01:16 PM
  #78
Danny2tek's Avatar
Thats correct VIP1
Old Aug 19, 2010 | 01:14 AM
  #79
LOTTI99TA's Avatar
Thanks VIP1.. I found them ..$34.95 per housing for the highs and lows. What about the fogs...? Do I need to by a housing for them as well or can the stock housings work...?
Old Aug 19, 2010 | 01:32 AM
  #80
LOTTI99TA's Avatar
Hey Danny2tek, You seem to be on the pulse with this topic. I'm new to the site and I'm on info overload when it comes to the HID kits. (I think I've read every thread) I checked out the " DDMT " site but I'm not sure what to order there for my low beams and fogs. I think I want the higher color temp 8000 +.. but that's about all I've figured outso far. Can you give me any specific recommendations on what kit(s) to buy there (or anyplace else for that matter)...?
