New Kit for the Birds
The LMC kit comes with a male pigtail for each lamp you order. You'll have to add this to your factory harness to plug into the 9006 connector on the ballast. You can use butt connectors, male/female spade connectors or you could depin the factory connector and pin in the 9006 connector. I did the later.
There are few options out there.
Here's the beginning of this thread. Most of us are trying out the LMC sealed beam housings and DDM tuning 35watt ballast with 5k or 6k color temperature.
https://ls1tech.com/forums/stereo-el...kit-birds.html
Another option which is very expensive is a complete plug and play HID kit with projectors and shields.
https://ls1tech.com/forums/appearanc...ro-gp-2-a.html
This is the official light LS1Tech FAQ lighting section.
https://ls1tech.com/forums/appearanc...hting-faq.html
And how are you guys putting HID's in the fogs. Are you just buying a 880 HID kit and using that, or is a special housing needed? thanks!
