Where can I find some ACC power to tap off ?
OK I can find a million places to tap batt power with a add a circuit in the engine compartment but I can't find any accessory ..ie.. only hot when the key is on power.
PLEASE HELP !
PLEASE HELP !
I think I will try and find that pink in the consol from my ASR and use just a few milli amps of that to control my relay coils and then just pull the main pwr for that 30A pig heater off the Batt.
Thanks guys
Check this Kragen add a circuit out guys, I am getting a few for my tool box right now!
https://ls1tech.com/forums/nitrous-o...er-relays.html
There are 2 open slots in the driver's side fuse box.
IGN=12v switched (ignition on)
ACCY=12v Retained Accessory Power (RAP)
If you are looking for spots under the hood you can jump off the headlamp door slots.
I used one in my Camaro for an EWP. (ignition on)
Thanks shoemike, I will go take a look.
