Big 3. Is there any sense in removing old wire?
Other than ridding the engine bay of some clutter, is there any reason to disconnect the original wires? Obviously I will remove the engine to chassis wire, but perhaps I am becoming old and lazy.
So:
Do I cut and remove it, or do I run both and let the electricity follow the big assed 1/0 gauge path of least resistance?
So:
i plan to do this in the next few weeks and I will probably keep the stock wiring in place. Also, the circuit will not simply flow down the path with the least resistance but will be split between the small and large wires inversely proportional to their resistances. If one wire is 1 ohm and the other is 2 ohm then 2/3 of the current will flow through the 1 ohm wire and 1/3 through the 2 ohm wire. The product of the current and resistance must be the same in both wires. 1*2/3=2*1/3. Also, a 1 ohm wire in parallel with a 2 ohm wire will now give you an overall resistance of 2/3ohm. Just an FYI.
I don't know. I don't know if it helped, but I did it with extra 1/0 because I had the extra wire and pulled out all of the original.
I think it is probably a good idea. If I did it another setup, I would do the "Big 3.5" again.
