PAC SWI-PS Help!!!
Old Dec 31, 2010 | 04:27 PM
99blue-Z's Avatar
Question PAC SWI-PS Help!!!
I have recently installed a new wheel into my 99 Camaro. I currently have a Sony CDX-M7815X installed, so I purchased a PAC SWI-PS to let the steering wheel controls work. Everything works fine, with the exception of the Volume control. The Vol. up button turns the volume down, and vol. down goes into the sound settings when I press it. Like I said everything else works fine so I don't think it is a programming issue. PAC keeps telling me to reassign the functions, (which I have tried numerous times) and Soony tells me I can't modify the head unit itself. Any help would be appreciated!!!
Old Jan 1, 2011 | 02:17 PM
95TAJade's Avatar
Reprogram it with the car running. The slightly lower voltage makes the PAC SWIps module act stupid. Oh and the cold weather will also affect how it works too. I ran with one for about 6 months before the ASWC piece hit the market and that little guy works phenomenally!! Oh and it auto senses your cars controls and what radio you're using. I went from a Kenwood to a Pioneer and now I'm running an Alpine...ALL with the same steering wheel control interface module!!
Old Jan 9, 2011 | 01:57 AM
LilJayV10's Avatar
Can you tell me what the ASWC piece is and hows it different from the PAC SWI-PS
I have been looking at the SWI, I didn't know there were other options. Thanks for the help.
Old Jan 9, 2011 | 11:11 AM
jaysan's Avatar
can you post pix of how its wired up ? I have having a hard time with mine I just bought
Old Jan 9, 2011 | 04:49 PM
LS1121's Avatar
Sounds like a programming issue to me also. You can program any button to any function. I had to program mine 3 times to get it right , the problem was me not the hardware. Also on my Sony after I got it right it went crazy, the plug that goes into the back of my Sony was a right angle plug and did not go all the way into my unit so when I would hit a bump it would just come out a little, enough to make it act crazy. To fix this I had to cut away a little of the black plastic on the plug so it would go all the way into the radio. No more problems.
Old Jan 15, 2011 | 11:50 PM
LilJayV10's Avatar
This^
Old Jan 16, 2011 | 12:17 AM
SnakeStomper's Avatar
First time I've heard of ASWC too ... looks to be pretty easy to setup and works with all major brands ... http://www.sonicelectronix.com/item_...xess-ASWC.html
Old Jan 16, 2011 | 12:27 AM
LilJayV10's Avatar
I see KeeAudio sells both. When I order my speaker package from him I will ask which he prefers.
