Run Ipod without a HU?
Old Jan 22, 2011 | 05:05 PM
w3s1c0a5t's Avatar
Default Run Ipod without a HU?
Just curious if anyone has tried this or has a good idea of where to start.
Want to run no headunit or antenna to save weight. Besides I would be happier just having the ipod anyway..
Thanks for any help guys.
Old Jan 22, 2011 | 07:41 PM
pentavolvo's Avatar
gonna need an amp
Old Jan 22, 2011 | 07:51 PM
w3s1c0a5t's Avatar
True.
I wonder what the stock AMP weighs. Let me do some looking. My car did not come with the monsoon or anything.
Old Jan 22, 2011 | 09:43 PM
WhiteBird00's Avatar
Ungrounded Moderator
If your car doesn't have Monsoon then it doesn't have a stock amp (at least not outside the head unit). Besides, the Monsoon amp takes speaker-level input which an iPod can't produce.
Old Jan 22, 2011 | 10:26 PM
w3s1c0a5t's Avatar
I was referring to picking up a stock monsoon for my car. But thank you for the information.
Would I need a certain kind of amp for this?
I am not much of an audio guy. Sorry for the spoon feeding lol.
Old Jan 22, 2011 | 10:36 PM
vjo90rs8's Avatar
find the cheapest head unit that supports an iPod and that will be your amplifier.
Old Jan 22, 2011 | 10:41 PM
Cheap Guy's Avatar
I think the problem is that if you get an amp, it's probably going to weigh as much if not more than a cheap HU, so you're not really going to save any weight. Since you're not dealing with the Monsoon stuff (amp), you can also save weight by buying the lightest speakers you can find.
But...I'm always game to follow threads where someone is trying something new so if you do it, let us know how it turns out!
Old Jan 22, 2011 | 11:57 PM
bad_408_vert's Avatar
I threw the idea around for a while but didn't get around to it.
You need a 4 or 5 channel amp depending on if you will also be using a subwoofer with the speakers in the doors and hatch.
The speakers would run off the amp.
A 3.5mm Stereo Mini RCA Aux Cable would connect the ipod to the amp.
The only thing I wasn't able to figure out how to send the signal from the ipod to amp when you connect/disconnect the ipod. In a headunit's harness there's usually a blue wire (signal) that does this for you.
Without some sort of a signal the speakers will always have that buzzing sound because they think they are on.
Maybe someone can chime in for that part of the question.
Old Jan 23, 2011 | 07:58 AM
There are amps on the market that use signal sensing to turn on rather than a remote turn-on wire (the Monsoon amp uses signal sensing). They aren't very common but can be found - some JL amps feature signal sensing.
However Cheap Guy is correct... if weight saving is your concern, a head unit with iPod input will weigh less and be easier to setup than an amp without a head unit.
Old Jan 23, 2011 | 09:25 AM
Cheap Guy's Avatar
I've noticed that a few of the major HU manufacturers (Sony for example) have decided to do something similar to what the OP wants to do - HU without CD since very few people actually use CDs anymore in their cars. I think they're called "Digital Media Receiver" or something like that.
I guess this would be the "lightest" way to play a iPod since I guess the lack of the CD unit saves some weight.
Whitebird00 Thank you for clearing that up.
If I were to do this, it would be for aesthetic reasons and not so much for weight reduction.
Old Jan 23, 2011 | 11:24 AM
pentavolvo's Avatar
vibe litebox 4 channel, small, not too pricey, and remote sensing
Old Jan 23, 2011 | 05:09 PM
w3s1c0a5t's Avatar
Great info guys. Thank you. I also plan to remove the antenna. The assembly weighs some im sure with the motor, bracket, etc.
I know Im not going to save a ton but I would rather have the Ipod setup anyway. Saving a little weight would just be a plus. 5-10lbs adds up.
