Hard-Wiring Satellite Radio and V1
Old 12-05-2011, 09:28 AM
Predator's Avatar
Question Hard-Wiring Satellite Radio and V1
Hey Fellas, I have a satellite radio coming and I plan on getting a Valentine One radar detector. I was wondering if it was possible to hard-wire both units into the yellow wire in the radio harness? I know about getting a cigarette socket for the sat. radio, but I was wondering if an overload would occur by having two devices wired into the same yellow power wire. Thanks.
Old 12-05-2011, 02:53 PM
Predator's Avatar
Ok, I've been trying to figure this out. I think I'll get power for the satellite radio from the yellow wire in the radio harness using a cigarette adapter plug. For the V1 I'll go under the hatch panel according to Jim's instructions on LS1HowTo.
Just wondering, ever get the feeling you were talking to yourself?
Old 12-05-2011, 09:51 PM
WILDMN's Avatar
It depends on the current draw for the items. Without know the draw it would be hard to say for sure.
Old 12-06-2011, 01:08 AM
Predator's Avatar
Oh okay. It's the same concept as a house circuit. I think the satellite radio only draws 5 amps, so that leaves me with 10 amps to allow for the radar detector? Thanks.
Old 12-06-2011, 01:53 AM
Predator's Avatar
I looked up the power requirements for Valentine One:
"225 mA typical standby, 425 mA maximum
alarm condition"
Does that mean it draws 2.25 amps in standby and 4.25 amps in alrm condition? If so it looks like the combination of sat. radio and V1 would only draw 7.25 to 9.25 amps on a 15 amp circuit. Is this correct?
Old 12-06-2011, 04:31 AM
Predator's Avatar
Is this the kind of cigarette socket I should get for a 5 amp draw satellite radio spliced into the yellow wire in the radio harness?
http://www.amazon.com/Parts-Express-.../ref=pd_cp_e_4
Old 12-06-2011, 07:36 AM
Predator's Avatar
Thanks Whitebird, I got the tiny font from copying the V1 .pdf User's Guide.
Old 12-06-2011, 07:44 AM
Ungrounded Moderator
WhiteBird00's Avatar
alarm condition"
Actually... no.
A milliamp is one thousandth of an amp (not one hundredth) so 425 mA is less than half an amp. That shouldn't be a problem for adding to the radio circuit.
The circuit you're talking about is 15 amps maximum total - including the radio itself and the steering wheel controls. Adding the satellite radio could potentially cause problems. However, my experience is that those plug-and-play satellite radios don't draw anywhere near the amperage of the included 5A fuse - more like 1.5 to 2 amps. You should be okay splicing into the radio circuit as long as you don't change the factory fuse size. If the fuse blows, find a different place to wire the accessories - don't install a larger fuse.
Old 12-06-2011, 07:56 AM
Oh, and yes... that is the correct type of cigarette lighter socket.
Old 12-06-2011, 08:13 AM
Predator's Avatar
Thumbs up
Originally Posted by WhiteBird00
Actually... no.
Wow, I wasn't even in the ballpark lol. I even forgot about adding in the HU and steering wheel controls.
Just to be sure, I've seen lighter sockets with one wire and two wires. Do I want the one with just one wire coming off it? Even the one in link looks like it might have two wires but they're not separated apart. I don't know how closely you looked at it. Here's one that looks like it has a single wire coming off it:
http://www.amazon.com/Parts-Express-...3180669&sr=8-3
Thanks for the help.
Old 12-06-2011, 11:50 AM
TruBloodTransAm's Avatar
I couldn't see the V1 drawing much power at all. I've left it on by accident for days at a time and never killed my battery.
Old 12-06-2011, 12:03 PM
Predator's Avatar
You're right, it only draws between a 1/4 to 1/2 an amp (thanks to Whitebird for clearing up my misunderstanding). Thanks for the confirmation.
BTW TruBloodTA, how would you rate your V1? Are you happy with it?
I was thinking about getting some Laser Veil (that stuff you paint on so that LEO's laser has a hard time locking on), but I learned that the areas that reflect the most light are the headlights and the front license plate. It seems that the Trans Am is pretty stealth from the factory with pop up headlights and the front plate cover. Even the antenna is black instead of chrome like most antennas and reflects less light. Pretty cool.
Old 12-06-2011, 12:07 PM
Predator's Avatar
Whitebird, here's a clear example of a lighter socket with two wires coming off it. I assume this is NOT the type I want, correct?
http://www.batteryspace.com/browsepr...Connector.html
Old 12-06-2011, 01:29 PM
It's great, I love it. It's saved my *** several times over the years. Love the directional arrows too.
It won't save you from Laser (instant-on) though...
Old 12-06-2011, 01:39 PM
Predator's Avatar
Great to hear about the V1. I know laser is tough to beat. Just wondering, do you run into laser traps that often or is it practically always radar? I know laser guns are pretty expensive, around 5000 bucks a pop. Isn't it mostly state cops that use laser?
Old 12-06-2011, 03:11 PM
I've been hit with Laser a few times, and yes it was on some rural highway, probably a state trooper. Luckily, I wasn't speeding when they hit me.
Maybe it's just me, but it seems like when I get hit with Laser the cop is usually stationary. Makes it a bit easier to spot, especially on open country roads. The V1 is great for K and Ka bands, it shows the signal strength and direction. Usually when I'm being hit with these two bands, the cops are driving by and they are going in and out of range.
Old 12-06-2011, 03:33 PM
Predator's Avatar
Yes, the cop operating the laser can't be moving. It has to be carefully aimed at the target.
I can't wait to get my V1. Let the games begin LOL.
Old 12-06-2011, 03:47 PM
Moderator
jimmyblue's Avatar
I pull V1 power from my rear view mirror feed, but I gather
this is maybe unique to 'verts (having power to the mirror).
Old 12-06-2011, 04:34 PM
Predator's Avatar
Hi Jimmy, I was wondering how that might work. Where did you mount your ground wire and junction box? Since I plan on placing the V1 above the mirror, it seems that getting power from the mirror makes the most logistical sense. Thanks.
Old 12-06-2011, 04:43 PM
If you're going to mount it there, might want to check out the BlendMount. It's a little pricy but gives it a very clean look when installed.
I think there are 1 or 2 members on here who have it.
Quick Reply: Hard-Wiring Satellite Radio and V1
