Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Install Steering Wheel with Radio Contorls<br>Step by step instructions for do-it-yourself repairs.
Axxess ASWC Install Walk-Through: 2001 Trans Am Steering Wheel Controls
Copy & Paste Moderator
I typed your question into google and found these:
https://metra-static.s3.amazonaws.co...ument_100A.pdf
http://metraonline.com/files/products/INSTASWC_web.pdf
Is that what you need?
2x what RomRod said, thanks for this thread, it is definitely the most helpful getting the Axxess connected to a late model F-body. I am installing a Sony Android Auto/Apple Car play receiver. I will order another Metra 70-1858 to get a donor wire to pin into spot #14 in harness. Quick re-ash: Wire from Axxess to Metra pigtail: black to black, red to red (accessory power), yellow/green stripe (may look like golden rod yellow or Orange with green stripe, mine is def yellow) to pin #14 (wire from donor Metra harness). #14 position is the one right across from the gray right front speaker positive (no black stripe). I will most likely cannibalize either a yellow or orange wire from the 2nd Metra harness I just ordered. Thanks guys!
UPDATE: I added a parking brake bypass to the harness. In my situation the previous owner ran new speaker wires to speakers (guessing ty bypass the Monsoon system). I was able to use one of the speaker wires as the wire for pin #14. I connected a backup camera also, works great but I wired it so it only works when in reverse. If you are more patient, you can run a wire to the backup camera to power it when ever you want, the head unit can view the camera anytime as long as it is powered.
More importantly, directions on the web for a double din radio install want you to cut the lower section of the dash radio opening to allow a double din radio to fit. If you buy this particular Sony XAV-AX150, the innards of the radio is positioned at the top half of the DIM. I did not have to cut any of the factory plastic out of my dash to install this radio. I did have to cut about 1/2" from the bottom of the mounts in the Metra 95-3312G kit, but I would rather cut up the install kit than the factory dash. I attached some pictures.
