low voltage
Old Jul 28, 2012 | 12:26 PM
astro11271984's Avatar
Default low voltage
So i took my alternator,battery and starter off had oreilys check each one and past the test but im still getting low voltage. Anybody have any ideas on what else i should be looking at
Old Jul 29, 2012 | 06:55 PM
So i did the whole taking off the positive cable of the battery and still was running but when i turned on the ac it died should i assume the alternator passed the bench test but is still bad?
Old Jul 30, 2012 | 11:33 AM
sjsingle1's Avatar
is it the original stock alt?
Old Jul 30, 2012 | 12:24 PM
ive switched from factory to a reman then to the truck all in the last year i do have a 10 inch sub with a small kenwood amp nothing big maybe the system is killing the alternators?
Old Jul 30, 2012 | 11:20 PM
sjsingle1's Avatar
all remans? seems some here have lots of problems with remans thats why i ask
Old Jul 31, 2012 | 12:03 AM
Yah i think ill get the 145 amp brand new
Old Jul 31, 2012 | 03:08 AM
sjsingle1's Avatar
the problem with remans is that most builders cheap out and use china parts.....guess you can figure out how long they last
Old Jul 31, 2012 | 07:41 AM
yah the thing is if i take the positive cable off the battery car still runs its only when i turn on the ac that the car dies so im wondering if the alternator is still the cause guess ill have to get a voltmeter also
Old Aug 3, 2012 | 12:32 PM
Well i think i found my problem when i put the alternator after it tested good.I didnt tourqe the cable on the back of the alternator down so it wasnt making good contact.
