Stereo Display Lights Shot
Old Jun 23, 2013 | 11:23 PM
Bama99z's Avatar
Exclamation Stereo Display Lights Shot
Does anyone know if the display lights on the stereo display can be replaced? If so who on here does that type of work? The radio is a factory one in a Pontiac Sunfire? I know it sound stupid but this car has alot of sentimental value to be and I want to get it fixed ( if it's possible ).
Thanks
Old Jun 24, 2013 | 08:38 AM
wssix99's Avatar
Save the manuals!
Which lights? The buttons or digital character display or all of them?
Old Jun 24, 2013 | 12:04 PM
wssix99's Avatar
Save the manuals!
I missed that it was for a Sunfire. Here's a good thread on the Firebird Radios: https://ls1tech.com/forums/stereo-el...hen-i-did.html
Have you checked all your fuses and dash light switches?
You might also check out ReplacementRadios.com. They should be able to do bulb replacements/refurbishments for you.
Old Jun 26, 2013 | 03:11 AM
Bama99z's Avatar
Default Lights
wssix99, sorry that i didn't exactly specify which ones. The lights that are not working properly are the digital display. Some are working some are very dim. I will take a look at the link that you sent me as well.
Old Jun 26, 2013 | 08:21 PM
VIP1's Avatar
Copy & Paste Moderator
You mean it looks garbled? The solder points probably have some micro-cracks. Only way to fix it it to reflow the solder. There are some old threads on here about it.
Old Jun 26, 2013 | 08:27 PM
Bama99z's Avatar
It actually looks as if the lights that should light up the display have burned out. I may be wrong, but some of it lights up albeit it is very dim. That's what leads me to beleive the bulbs are burned out.
Old Jun 27, 2013 | 01:02 AM
VIP1's Avatar
If I remember correctly, there is only one or two bulbs behind the display and it/they are to the side. So if you are seeing certain segments dim, it probably is the solder.
Old Jun 27, 2013 | 08:58 AM
wssix99's Avatar
Save the manuals!
There is a twist lock (conventional) bulb that back lights the display. See post #26 and #27 in the link I attached above for more info on the part.
