Humount Wiring
Derek
On every aftermarket harness you have several key wires
Yellow= Constant battery power
Red= Switched power
Black= Ground
so to wire it so the lights come on with the key on connect the power wire of the humount to the red "switched power" and the ground to the black "ground" wire.
Red= Switched power
Black= Ground
https://ls1tech.com/forums/stereo-el...2-12v-key.html
http://www.crutchfield.com/p_1207018...e-Harness.html
What I did for the HUmount was to splice into 12v switched and the illumination wire, so it only comes on when I turn the headlights on.
