Led Turn signals?
You have two options - replace your flasher with an electronic one or add load resistors to restore the electrical load for the stock thermal flasher.
If you replace more than just the front bulbs you will need a flasher specifically designed for LED. You can find them online under various names... LED Flasher, No-Load Flasher, etc. Sites that sell LED bulbs usually carry the flashers (superbrightleds.com has them) and Amazon also has them. You need a 2-pin flasher for it to be a plug-in replacement.
You can also make a 3-pin flasher such as the Tridon EP34 work. It has the advantage of being available almost everywhere but you have to add an extra wire to make it work in an F-body. The three pins are labeled B, L and E - Battery, Load, and Earth (ground). You need to add a wire from the E terminal to a chassis ground like a bolt under the dash.
LEDs aren't analog - they're digital. And they also react to changes in power very rapidly which is why they work well for strobes. But they don't react to PWM the same as a normal bulb and the rapid switching causes them to fail prematurely. But F-bodies don't use PWM - they just have full 12 volts to the socket at all times so the "GM DRL" incompatibility doesn't apply.
However, LEDs (like all electronics) are sensitive to heat. Many inexpensive LED bulb don't have sufficient heat dissipation built in. They're fine for intermittent use like turn signals but fail because of the heat under constant use such as in DRLs.
Your LEDs didn't fail because of the "GM DRL" incompatibility but because they were too hot for too long. Look for higher quality LED bulbs that have heat sinks. V-LEDs has only recently added bulbs like that. superbightleds.com has had them for several years now and they come with a 2-year warranty - twice as long as almost everyone else. I've had a pair installed for three years without any issues.
