Would you ?
Old Oct 9, 2014 | 10:06 PM
Stan1911's Avatar
Default Would you ?
I have a monsoon system, 10 speakers and an amp. Pretty much all the speakers need to be replaced and the head unit does not play cd's anymore, E23 code.
Option 1 - Thinking on buying the component speaker package from Kee Audio $300 and maybe spending $200 on a head unit. That way I could use the installed/existing wiring and amp.
Option 2 - Get everything new but a spend a max $600 including running new wires and all.
Which way would you go, or is there a 3rd option I am not seeing.
Oh and this is on a 2002 Firebird.
These are the speakers I am considering.
4th Generation Firebird Speaker Package:
1.) CDT CL-61.2 6.5" Component Speaker System (doors)
2.) Bazooka 6.5" DVC Subwoofers (sailpanels)
3.) CDT CL-4EX coaxials (hatch)
Old Oct 9, 2014 | 10:26 PM
"MAC"'s Avatar
Just buy all new speakers and head unit. Go to bestbuy they can help you match up the right head unit if anything you need an adapter which i highly doubt you'll need.
Old Oct 10, 2014 | 12:21 AM
Daniel Richards's Avatar
get the best Kee Audio package you can afford and swap out the headunit, swapping out the amp and re-wiring everything is gonna add a lot more to the cost, but get a headunit with 3 full sets of RCA's that are atleast 4 volt preouts so that if in the future you want to expand your system you can.
Old Oct 11, 2014 | 12:13 AM
Stan1911's Avatar
Thanks for the replies guys, ordering speakers shortly and start researching head units. Not sure what (get a headunit with 3 full sets of RCA's that are atleast 4 volt preouts) is but I will find out.
Old Oct 11, 2014 | 12:53 AM
RCA outputs are how you connect aftermarket amps to the aftermarket headunits, lower end headunits typically only have 1 set of RCA's which would be used for connecting a subwoofer amp and it is typical to see them output at 2 volts, as you go to better headunits you see 2 sets of RCA's one set being the front output and the other set being switch able between either a rear output or a subwoofer output, then the higher end radios give you a front, rear and Subwoofer RCA (3 sets of RCA's), when you get into this level you start to see ones that have 4 volt outputs which gives a better signal to the amps resulting in better sound.
So in the future if you want to replace the factory amp you'll need a headunit with both front and rear RCA sets (2 sets of RCA's) then if you want to add a subwoofer while still running the other speakers off amps you need that 3rd set of RCA's.
As for brand I am partial to Pioneer myself.
Old Oct 11, 2014 | 01:01 AM
Stan1911's Avatar
Awesome, thanks for the explanation and great advise!
Old Oct 11, 2014 | 11:47 PM
M4N14C's Avatar
Go with option 1. I upgraded to Kee Audio level 3 speakers, then added a 10" stealth sub and a new head unit. System sounds crisp and hits hard all utilizing stock monsoon amp; not to mention a lot cheaper than rewiring a new amp.
Old Oct 12, 2014 | 08:56 AM
2nd Gen Fl 'bird's Avatar
Is this using factory wiring? If so I'm in. The days of going around beating my chest about 12" subs and 1000w amps are over. I just want like you have said, good hit and crisp.
Old Oct 12, 2014 | 11:33 AM
M4N14C's Avatar
Yes all the speakers (doors, sails, hatch) are using stock wiring. I did have to wire the sub to it's own amp but that's nothing compared to tearing out all the wiring and laying down new ones.
Old Oct 12, 2014 | 08:05 PM
"MAC"'s Avatar
I got a kenwood 7in lcd touche screen head unit and Panasonic speakers back in 09. I paid 1200 for it all, that covered parts and labor. I wanted the best headunit at the time and it was very expensive they are a lot cheaper now.
Old Oct 13, 2014 | 03:24 PM
98_1LE's Avatar
How much does a new head unit offer if going with the better Kee kit for Monsoon (Level 3 Premium IIRC)?
Old Oct 13, 2014 | 05:13 PM
M4N14C's Avatar
Kee Level 3 is just the speaker replacement. HU can go from $50 to $1500 depending on what you want out of it.
