10inc sub help
Old Jan 15, 2015 | 10:30 PM
redcamaro4140's Avatar
Default 10inc sub help
Hello I'm looking to get the best sub for my stealth sub box on my Camaro I want something that sounds Good and clean so if anyone has advised would greatfull thanks.
Old Jan 16, 2015 | 01:14 AM
Tuskyz28's Avatar
This go be a great thread here!!
Old Jan 16, 2015 | 03:18 AM
That suppose to be bad comment.
Old Jan 16, 2015 | 06:38 AM
Tuskyz28's Avatar
Nope, I honestly want to put the stealth box in my car but I know of I ask the question you asked I'm go get 50 different answers. Believe it or not most people are brand loyal to ONE brand and that's it. I'm not...... I'm like you I want what's go be nice and give me my best bang for the buck.
Old Jan 16, 2015 | 09:18 PM
Yea I hear hopefully some says something
Old Jan 16, 2015 | 09:52 PM
98z8uup's Avatar
This is going to be a good one. Do you have a amp yet, if so what's the power rates on the amp.
Old Jan 16, 2015 | 11:11 PM
Well I'm just seen what people are using in the f-bodys and what setup works the best.
Old Jan 17, 2015 | 08:26 AM
Tuskyz28's Avatar
What's the max you want to spend on the sub?
Old Jan 17, 2015 | 10:24 AM
SilverSS07's Avatar
Which box are you using? What's the mounting depth? What kind of music are you listening to? I have a TC Sounds Epic 10 in a DD Mods stealth box. Good SQ but lacking on the lower end- like around 60hz and lower. Sounds good for rock and country but not for rap or any music with a lot of low bass.
Old Jan 17, 2015 | 02:09 PM
pewterformula's Avatar
I ran a JL 10W6 in a stealth box in my Formula, and I run a Rockford P3D4-10 in my SS mated to an Eclipse XA1000 amp. I'm not going to win any competitions or anything, but for good clear sound it is great.
Old Jan 17, 2015 | 02:14 PM
Which ever sub you run, make sure you get a good amp with a rated output matched to your sub's rated power handling. Having an under powered amp or one with a lot of distortion will damage your speaker more than running too much power.
Old Jan 17, 2015 | 07:32 PM
What good amp watt to get with 10inx 500 to low of an amp
Old Jan 17, 2015 | 08:38 PM
SilverSS07's Avatar
https://ls1tech.com/forums/stereo-el...omparison.html
This is a thread I found from a while back. I still don't know what kind of music you listen to and what your goals are but for rap and other music with lower bass I would choose a speaker with a lower f3 in a small sealed box. What amp you need depends on what subwoofer you choose. Whatever the sub is rated for (example 500 wrms) you would want an amp that delivers 500 wrms at whatever ohm you plan on running the subwoofer on.
Old Jan 17, 2015 | 08:41 PM
I listen to little bet of everything so something good for everything
Old Jan 17, 2015 | 09:09 PM
SilverSS07 answered before I could. Choose the sub designed for your box and listening needs. Then mate an amp to the sub that you chose. You can spend all the money in the world for a box, sub, and amp, but if they do not mate well (volume of air space, mounting depth, frequency, power usage, etc) it will sound like crap. I don't listen to rap hardly at all, but primarily rock and country. Mine mate really well for what I listen to, but it also performs good if my fiance's daughter wants to listen to her music (she's 15... that says it all).
Old Jan 17, 2015 | 09:31 PM
It's going to be a stealth sub box on the driver side.
Old Jan 17, 2015 | 09:35 PM
Ive got a stealth box on the driver's side as well, but I've seen several different designs with different depths and volumes. Do you already have the box?
Old Jan 17, 2015 | 09:50 PM
No I don't have it yet but this the place I wanna get the sub from doubled mods subs
http://shop.doubledmods.com/10-Steal...Mstealth10.htm
Old Jan 17, 2015 | 10:03 PM
The Rockford P3D4-10 that I have would go great in that box.
Old Jan 18, 2015 | 01:32 AM
How does that sound and how does it hit? And what amp you running
