Auto Head light defeat options
Old Dec 15, 2015 | 04:30 PM
insidethreat07's Avatar
Default Auto Head light defeat options
I know this link shows how to do it, but i want to try and avoid breaking the damn dash pad in a million pieces
https://ls1tech.com/forums/appearanc...ml#post7096661
I also stumbled across this link as well. Not sure if it is another way of shorting the circuit
http://xse.com/leres/ss/drl.html
Would the top section in the second link virtually do the same thing? I do not want to get rid of the DRLs just the auto headlight feature.
Old Dec 15, 2015 | 06:22 PM
rwb's Avatar
rwb
I did this one
about 14 years ago and don't have any problems with it.
Old Dec 15, 2015 | 08:26 PM
Originally Posted by rwb
I did this one
The top section looks like it disables the DRL and the auto headlights at the same time. The only way to do the headlights only is under the dash pad from what I'm gathering
Old Dec 15, 2015 | 11:39 PM
FastrDamnit!'s Avatar
I've done the disable from under the dash cover a few times on my past cars and never an issue, just park it in the sun so the plastic is more forgiving when you pop it up.
Old Dec 16, 2015 | 07:48 AM
WhiteBird00's Avatar
Ungrounded Moderator
The soldering option listed at xse.com does exactly the same thing as using a ScotchLock under the sensor - it shorts the two sensor wires together causing a zero resistance that the module interprets as bright daylight all the time so the headlights never go on automatically. Both methods affect only the automatic headlights and have no effect on manual headlight control or the DRLs.
You can achieve the same thing without removing the dash pad and without opening the DRL module to solder by simply installing the ScotchLock connector across the yellow/black and light green/black wires at the blue connector of the DRL module. These are the same two sensor wires that you would short under the dash pad but in a more convenient location. Just unplug the blue connector to get some slack to work with, install the connector across the two wires to short them together, and plug the connector back into the DRL module.
Old Dec 16, 2015 | 05:42 PM
Awesome, thanks for the information, anyway to do it without possible breaking my dash pad is a plus lol, thanks again
Old Dec 21, 2015 | 02:53 PM
Spartan7's Avatar
I'm going to disagree from the LT1 side. LS1's may be different, but following that exact site and bridging the two pins in the module disabled the DRL's on my 97 (which was my intent).
Old Dec 21, 2015 | 02:59 PM
I'm afraid I don't have schematics for LT1 f-bodies so my assurance applies only to LS1 (98-02) models.
Old Dec 22, 2015 | 02:27 PM
Spartan7's Avatar
It was my understanding that you were speaking for later 4th gens only, I was just providing some additional info. If the DRL module is similar between 97's and later (which I'm unsure of), it might have similar effects.
Old Dec 23, 2015 | 04:20 PM
Daniel Richards's Avatar
another option is to sell the Camaro and get a TRANS AM, LOL.
Old Dec 23, 2015 | 04:26 PM
VIP1's Avatar
Copy & Paste Moderator
As long as its not a Canadian one.
(Canadian Firebird had auto-headlights.)
Old Dec 23, 2015 | 06:22 PM
ATXSS's Avatar
Thank you sir this worked perfectly for me and it took a whopping 9 minutes to do.
