99 TA cluster pinout?
Old Aug 28, 2016 | 11:07 PM
greenvortec97's Avatar
Default 99 TA cluster pinout?
Move if in wrong section but I am almost wrapped up with my MS3pro install and Was wondering if anyone here has the pinout for the gauge cluster?
Old Aug 29, 2016 | 07:35 AM
LT4vert's Avatar
This is from the 99 dealer service manual.
Old Aug 31, 2016 | 02:54 PM
Thanks so much!
Old Aug 31, 2016 | 06:02 PM
it appears there is no way to control the tach on the factory Cluster
Old Aug 31, 2016 | 06:19 PM
LT4vert's Avatar
True, the tach signal is sent to the cluster via class 2 serial data. If you need a tach signal your going to have to go to the pcm.
Old Aug 31, 2016 | 08:58 PM
Custom Gauges it is then... lol
Old Sep 1, 2016 | 12:06 PM
Are you sure it goes through the PCM? Does it go into the Body control module by any chance?
Old Sep 1, 2016 | 12:34 PM
LT4vert's Avatar
Yep should be pin 10 on the red connector. Its a white wire. It does not go to the bcm.
Old Nov 9, 2021 | 05:42 PM
reed 13's Avatar
I’m very new to this so please bear with me. I have a 2001 fire bird that I’m doin an LS swap on I have found my tach signal (pin 10) how would I go about hooking that up to my stock gauge cluster? Would I use the serial data wire? Thanks
