Blinkers Hesitating
Blinkers hesitate instead of blinking normally.
Just replaced all 8 bulbs in rear tail lights. Sanded, and scraped metal contacts before bulb replacement.
Cleaned front blinker bulb sockets as well.
Bulbs continue to do this after new rear bulbs, and cleaning contacts. When Hazards are turned on, they blink fine and normal. Only issue is when turn signals are used.
Any ideas?
Rick
Rick
Using the electronic flasher EL12 may make the signals flash without actually solving the underlying problem. Electronic flashers don't depend on current load for timing so they will usually flash even when bulbs are burned out or sockets are corroded.
Something I swear has changed since I took out the original flasher though. Because the stick felt so fragile, when changing lanes I would usually partially move it without it clicking into place to use the blinkers, and the dash arrows would come on with very little movement of the stalk. Since then I have to completely click the stalk into position before the arrows flash, it doesn't matter which flash I've tried. I do have a new stalk but my understanding is that it's a hassle to swap.
It sounds like the signal switch is just a bit more worn and needs to be fully engaged to work now. It's not really a problem since that's the way it's supposed to work. Having the switch engage just from light pressure is definitely nice though. I was bummed when it stopped working on my other car.
