2002 Camaro Headunit Upgrade
There isn't a head unit anywhere that will allow you to retain use of your factory external CD changer but almost all new units will retain steering wheel controls with the use of an adapter. There's lots of information in the Monsoon FAQ sticky at the top of the forum, including what other parts you'll need (steering wheel control adapter, wiring harness adapter, etc.).
Thanks this is great info. I'd be safe going with that RetroSound however I can't believe they don't have adaptors for steering wheel controls.
There is only one wire for steering wheel control in the factory harness and there should be a remote control connector port (like a 3.5mm headphone port) on the head unit. The exception is Kenwood which uses a blue/yellow wire instead of the 3.5mm port. You should not be connecting the dark blue steering wheel control wire directly to the head unit without an adapter like a PAC SWI-JACK, SWI-PS, or one of several other adapters. The adapter has the correct 3.5mm plug (and the blue/yellow wire for Kenwood) to connect to the head unit. Also, you should not be connecting any wires from the factory connector directly to the head unit without a harness adapter.
