FIXED: BOTH Headlights wont go up.???
I'm pretty sure its something electrical. I checked the fuses and they look good. I'm not sure what else to check. Anyone ever experience this?
I havent driven the car in months since Ive been installing the procharger & everything but the last time I drove it, both head lights flipped up perfect.
Side note: The last few days Ive been installing some gauges. I don't think I did anything to make the headlights not work.
I tapped into large pink wire under dash for my 12v ignition source and tapped into the brown radio wire for my lighting source.
The other possibility is that the mechanism is jammed and the resistance is kicking the motor off before it lifts.
So I connected it up real quick and turned the lights on, both came up. So, I still had to tuck it away, I had to put some force on it to get it into position where I wanted it to sit at.
I get it all situated and tried the lights out again. Now the damn passenger side wont come up! Driver side works great. No noise at all coming from the passenger side.
I bought another headlight control module and installed it. It Did not not fix the problem.
The headlight goes up just fine manually
Where should I look next? motor?
Am In testing this correctly?. As you can see, the connectors are removed from the headlight control module.
I turn the headlight **** to the on position.
I put the negative probe of my meter into the black pin, and the positive probe into each of the other wires. All wire show 12 volts except the far left orange wire. I'm assuming this is the issue of why my passenger light will now flip open???
So where does that bad orange go to? The interior headlight ****? If so I guess I can run new wire from it to the module?
as for the fuses, I swapped in 2 other good working fuses with the headlight fuses, this did not fix anything.
Problem was a blow fuse.
Not a headlight fuse like you all might be thinking.
It was the 15 amp Eng. CTRL in the other fuse block.
NOTE: if you shove your multi meter leads into the pigtail like I did (testing for power) you will need to very lightly crimp the little female pins that the wire crimps to, so that they fit the male pins on the control module nice and snug.
