Gentex 221
Ps I have ign #1 going to radio yellow wire
grd#2 same as on car
#6 I have going to white wire (same)on car
#7 going to blue 12v on car
I'm not familiar with Lincoln mirrors. If it has two ground wires (one for courtesy and one for map) then you would connect the courtesy ground wire on the mirror to the white wire in the car and the map light ground wire to the black wire in the car. If it doesn't have two ground wires - perhaps it doesn't use the mirror lights as map lights - then you would connect the ground wire from the mirror to the white wire in the car and leave the black wire in the car unused.
- dark blue/white is power that is on at all times except when the BCM goes to sleep about 15 minutes after the car has been shut off (battery saver mode).
- black is ground that is available at all times.
- white is ground which is controlled by the BCM. It is only available when the courtesy lights should be on.
If that still isn't enough of an explanation, perhaps you could post the list of wires on the Lincoln mirror.
Figured I do some research and get ahead of it.
So here is a picture of the wires coming from Gentex 221
Ebay seller said that the wires are the following:
Blue/white - 12v
Black/Green - Ground
Yellow - dome
Pink - map lights
From what I gather from your post.
I should connected them like this:
let me know what you think?
I couldn't find any wiring schematic that matched your mirror but I did find information that included wires for the three center positions in the connector (missing in your mirror). I would assume that the connections are the same for the four outer wires you have but I would test it before installing. The information I found indicates that the blue/white wire should get ignition switched power for the auto-dimming function but I suppose there's no reason you couldn't use the factory dark blue/white wire - it will stay powered until the BCM goes to sleep but I guess that's not a problem. The black wire should indeed go to the factory black wire for constant ground. The pink wire is supposed to have battery (constant) power so you should connect it to the factory dark blue/white wire along with the mirror's blue/white wire. Finally, the yellow wire is supposed to be connected to the door switch so that it gets ground when the door is open in order to turn on the courtesy (dome) lights. You don't have that option with the factory wiring but I imagine the factory white wire would be a close-enough substitute. I don't know how well the mirror will handle the theater dimming effect... you'll just have to try it and see.
If you have the mirror and access to a 12V power supply - or even just a car battery - I would test those connections before trying to install in your car. Connect both the blue/white and pink wires to 12V positive. Connect the black wire to 12V negative. Check the compass. Test the map lights. You may be able to test the auto-dimming using a flashlight but it might be difficult to see the effect. Then test the courtesy lights by touching the yellow wire to 12V negative and see if the lights turn on. Then take the yellow wire away from the 12V negative and check that the lights turn off.
If all of that works then you have the correct connections and can wire them into the car. You may find that the compass loses calibration all the time because it has no power when the BCM goes to sleep. The mirror was designed to have constant power not power that shuts off 15 minutes after the ignition is turned off. I don't know if that will happen or not... you'll know by the display showing C or CAL. You have to drive the car in at least three circles at less than 5 mph to calibrate - the C or CAL indicator will turn off when it's successfully calibrated.
update**
So after about 15 mins the mirror lights turn off is there anyway around this ?
