Dash lights and tail lights out
Does the fuse blow as soon as you plug it in or only after you turn on the lights? If it blows immediately then you know the short is in one of the orange wires running from the fuse to the headlight switch and the DRL module. That's actually good news because it limits where you have to look. Another easy one to check is the fog light circuit... turn off the fog light switch and replace the fuse again - if it doesn't blow when you turn on the lights then you know that the problem is somewhere in the fog light circuit. Again, that's a good thing for narrowing down where to search for the short.
Otherwise, you're just going to have the tedious job of tracing the brown wires to find the short. You can confirm the short with a multimeter by checking continuity to ground on the brown wire at one of the running light sockets but that will just confirm what we've already surmised. Unfortunately, all of the parking/running light wires are spliced together not far from the headlight switch so confirming that there is a short to ground from one of the sockets doesn't help locate it - every socket will show the same short.
