Tach not working
Old Apr 10, 2023 | 06:17 PM
PenrodRacing's Avatar
Default Tach not working
I know there’s a lot of old threads on this but I can’t figure it out, my car is a 02 ss bought as a roller bored a gen 4 5.3 out to 5.7 used front cover and ls2 the half moon timing gear and chain and cam harness extension I have tried the the outside cam wires swapped and unswapped and cannot get my tach to work I’ve checked all the fuses they’re all good car starts up and runs fine for not having a very good tune it in just enough to get it to start and idle any help would be appreciated
Old Apr 10, 2023 | 06:31 PM
RB04Av's Avatar
Stepper motor in the dash
Quit messing with the motor
Old Apr 10, 2023 | 06:44 PM
Strutaeng2's Avatar
Hook up a scanner and see if your ECU is seeing RPM. If it is, chase the cluster as was mentioned. If not, then look elsewhere. Cam sensor/wiring maybe?
Old Apr 10, 2023 | 06:57 PM
It goes to 0 whenever I start it would it still be the stepper motor?
I do have rpm signal when we hook up the laptop
Old Apr 10, 2023 | 08:28 PM
01CamaroSSTx's Avatar
Factory tachometer not working?
Old Apr 10, 2023 | 10:45 PM
Yes factory tack
Old Apr 11, 2023 | 06:01 AM
klinznilk's Avatar
Which company are you using for the camshaft extension harness?? If its RACETRONIX.... its most likely pinned wrong. Mine from them was pinned wrong and once we flipped the two wires around it worked correctly. Just something to look at.
