Turn Signals Work Intermittently
After having my flasher go out, I replaced first with a Novita EL12. Then the turn signals stopped working next day. Replaced EL12 with the EF32RLNP flasher.
Added LED front t/s bulbs to replace a burnt incandescent. I cleaned contacts and now all lights work.
Here’s the issue: When cold and early on in drive, turn signals work fine. Usually much later on or on the return home drive, turn signals stop working completely, or intermittently. The switch sounds the same and headlights, high beams, wipers work. Sometimes I even hear that extra click from the EF32RLNP, indicating it’s getting initial power.
Since I’ve not found much how to material on replacing the turn signal switch in these, does this sound like something anyone else has encountered? Thanks.
Now, if you want the best and don't mind the cost, VLEDs has bulbs which are specifically rated for DRL use, but they range from $32 each to $160 per pair depending on model.
I have had good luck with JDM Astar 3157 bulbs for DRL / Turn signal use lasting up to two years even when on 8-10 hours daily on long trips. They're available on Amazon for about $30 per pair.
I’ll give the no-load flasher a try along with the new LEDs.
Determined the intermittent turn signals was due to a loose connection on the flasher relay… which can definitely get loose again if the under dash compartment heats up on a long drive. I checked the interior DRL fuses (#1,2,5,9) and they all work.
The JDM astars (with dielectric grease applied) did not like the slightly corroded sockets. The sylvanias worked fine so I put those back in.
So next question, what can cause DRLs (with headlights off) to fail?
Did you ever get anywhere with this? My signals are intermittent as well. I've replaced the flasher and I'm running regular 3157 bulbs. I'm leaning towards the stalk switch but not really convinced. It feels just like a normal one.
Just need to replace those darn cracked DRL housings and corroded sockets now…
