remote start.
thats rediculous. When installed properly theres NO DIFFERENCE in operation between the 2.
I myself would go with a viper 791 unit...available on ebay for roughly 200~
IIRC though the place i worked that instaled it still managed to have an idiot crash is mustang through his and his across the street neighbors garage when he remote started.
it can be done, i had it for 2 years without a problem. just be smart with it, if you dont know what your doing, have someone hook it up for you
Isn't there a remote start that only engages the starter for as long as you hold the botton down? This would solve all your problems if you see the car start to lurch forward you just take your finger off the button. And if you have it in a high gear the car will stall out and not lurch forward.
I had one on my 95 Z28 M6 and I accidentally tried starting a number of times with it in gear (parking brake on) - the car never moved. It just rocked a bit and gave up trying to start. If your parking brake can't hold against the starter motor then it needs to be adjusted.
