which 2way/start would you go for?
its the Viper 791XV
and the audiovox/prestige 996 model.
which would u guys go for and if u have any of them how are they working for you on the f-body.
what bypass modual will i be needing.
DO NOT cut the bypass wire and put resistors in as then anyone with a screwdriver can start your car! Unless you hook up the starter kill. But still that is getto. Get the DEI learnable bypass. Oh and a 5wire for the door locks on the BCM passenger side under glovebox.
why would he buy a 791 and not hookup the starter kill
.. gHetto > paying 50 bucks
Your car do what you want. But there is a right way and a wrong way to do every thing!
Viper 791xv
DEI learned bypass (555G on ebay, but does not show camaro/firebird)
5 wire hook up for door locks (454T, says it is a 5 wire door lock hook up)
Window roll up and down (530T)
Proximity sensor (508D)
Audio Sensor (506T)
Viper 791xv
Audio Sensor (506T)
The Viper 791XV is the best 2-way on the market. I have that in my 05 Cavalier (winter car). I put the Viper 650XV in the WS6. Just wanted a good alarm w/prox sensor (508D) and window rollup (530T).
To say the 791xv is the best is close to true but not realy, as I said the honet 2way is the very same thing but has clock,alarmclock,and car temp built in for $40 cheaper (at cost).
Any alarm is only as good as the install. More so on a ALARM as it needs to be not seen! I took my Escalade in for work at the dealer they removed the under dash area and never knew it had anything on it!
My camaro has the 791xv with GPS, prox sensor,and pizzo sirens. Ready to go in! And I do my own installs. best way to know the job is perfect! Oh and I removed my dash for the install.
as for the warranty, they have a lifetime warranty, if installed by an authorzied dealer. if you buy it on ebay, you have no warranty
the 791 includes the 5 wire relay. you should also get a back-up battery, and some mini piezo alarms, and a mercury tilt switch, or another hood pin (1 for hood, 1 for hatch) you may also thing about gettting the trunk pop solenoid from dei
as for the install, if you never installed an alarm before, good luck, i have the wiring diargams for you if you would like them, pm me.
jimmy
jimmy
Did a search on ebay with no results. I also did a search on ebay for GM VATS bypass and came up with this:
Ebay GM VATS bypass
Is this what I need? I thought we had the passlock II?
I am planning on going dei all the way.
jimmy
As for the trunk pop nothing extra is needed as it is a electric pop already! And there is also a factory trunk pin (orange/black + blue plug at the BCM on a 2001 camaro).
I wouldn't wast time and money on extra mercury switch the shock and prox sensor will cover that fine. the pizzos are painfull that is why they call them pain generators. I have 2 inside the car.
Ebay GM VATS bypass
steven,
the 652t is just a resistor back, it has all the resistence values for the passlock . you do not need it, you could go to radio shack and buy resistors.
I just pmed you the wiring, you will still need to double check with your DMM
