starter kill
Old Jan 26, 2005 | 05:02 PM
darkecho's Avatar
Default starter kill
I am going to install a starter kill like the one on bfrankers site (i already have the parts just need help with finding the right wire) I am going to set it up so that you have to hold the passenger side window up button while turning the key, (or maybe a different button, not sure yet) but the issue is that the wire i need to cut is a Yellow wire under the steering wheel and that will be the first place a theif looks to hotwire a car, im looking to go down stream if possible like in the bfranker site to under the passenger kick panel/glove box area, according to bfrankers site there is a thick purple wire but i have yet to find it, he also has an alarm installed AND his car is a 96, mines an 01 bird... so i dont know if the wiring is the same. anyways. has anyone got a suggestion on where i can find this purple wire before i go tearing away at my dash again, i suppose i could always take everything i can out and try to follow the yellow wire as far away as possible... but that would suck anyways, suggestions? maybe ill just follow the yellow wire as far as i can under the driver side panel..
thanks
Old Jan 26, 2005 | 05:24 PM
BigBadWolf's Avatar
My suggestion is: www.ravelco.com
After lots of investigation, for less than $300 this is as close to bulletproof as you get. A kill switch can still be cicrumvented by a reasonable smart thief.
Old Jan 26, 2005 | 05:28 PM
BigBadWolf's Avatar
https://ls1tech.com/forums/showthrea...7&page=4&pp=20
Scroll down to about the middle of this page.
Old Jan 26, 2005 | 05:37 PM
darkecho's Avatar
i dont want a 300 dollar system, i want a 5 dollar one lol... i just need to find the purple wire!!
Old Jan 26, 2005 | 05:40 PM
darkecho's Avatar
and if i go "downstream of the steering wheel, whos going to have the time or brilliance to 1. suspect a starter kill and 2. go looking under the glove box? i think its pretty cheap peace of mind
Old Jan 26, 2005 | 09:21 PM
Phoenix 5.7's Avatar
since you already have the parts, sounds like a good idea. for extra security, a fuel pump shuoff under the car would completely disable the car
Old Jan 27, 2005 | 03:24 PM
darkecho's Avatar
hmmmm fuel shutoff... i wonder how many would suspect that? lol... i think ill stick with the starter for now...i still havent found that damn purple wire though!!!
Old Jan 27, 2005 | 04:10 PM
BitViper's Avatar
Darkecho..I'll do it for ya.....
WERES THE PURPLE WIRE....!!!!
Your welcome
Old Jan 27, 2005 | 04:18 PM
it may not be purple in your car. following the yellow wire amy be the easiest thing
Old Jan 27, 2005 | 06:41 PM
darkecho's Avatar
sounds like a plan, thanks!
