Stock Speaker Sizes
Okay, yes i have searched and read through some threads...
Now I have an '01 Camaro. The door and b-pillar speakers both, from the factory, are 5.25". I understand that 6.5 or 6.75 can go in the doors, with a custom bracket. No biggie....
What I dont get is, how do you figure the rears are 6.75 also? Are you guys making a bracket to drop in larger rears as well? I have just glanced so far, so I am not really sure on clearances. But to me, it looks like it may be a bit of work to fit 6.75's in the rear. The door, maybe. The rears????
Also, I have read in some places the rear speakers are dual voice coil subs, but other places I have read different. Either way, I believe they are to act as sub and mid bass, so a coaxial is a waste to put in back there.
For the fronts I am thinking of going with Infinity 6002si, because they have a good sensitivity of 92db, and they are no to expensive. Being the stockers are 2ohms, and aftermarkets will be 4ohms, I believe a good sens rating is required for decent volume.
Anyway, can anyone clarify some of the above info?
Originally Posted by shouldaboughttheZ
The Trans Am has the dual voice coil subs. The Camaro only has single voice coil subs, but both subs have the same ohm level.
The rear fill are only 4". The sail panels are the subs of the 6.5". You might have gotten confused on the location they were talking about.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Actually I am aware of the two.. And realize the rear hatch area speakers are 4". But the side panel ones, the b-pillars that sit next to the rear passenger seats, is a 5.25" speaker. It looked liked one, so to be sure I measured, and sure enough it is in fact a 5.25, not 6.xx...
Here is the rear side panel (b-pillar) Speakers.
well you got 2 choices...
1...Cut the hole bigger to fit a 6.5" and put a sub in there.
2...Audiobahn makes a 5.25" woofer that would work.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
