Fan Switch Method Help???
Old Jun 17, 2005 | 03:03 AM
Jpr5690's Avatar
Default Fan Switch Method Help???
OK MY PLAN IS TO CONNECT A WIRE TO BOTH THE BLUE AND GREEN FAN GROUND WIRES.. THEN RUN THAT WIRE TO A SIMPLE ROCKER SWITCH THAT HAS A GROUND PLUGED INTO THE OTHER SIDE....
WILL THIS TURN ON BOTH THE HIGH AND LOW SPEED FAN WITHOUT THROWING ANY CODES OR MAKEING ANY OTHER PROBLEMS..?
Old Jun 17, 2005 | 03:19 AM
Jpr5690's Avatar
Ok Guys I Did It In Autocad To Clarify What I Mean ....
Old Jun 17, 2005 | 09:29 AM
shouldaboughttheZ's Avatar
I am assuming you are trying to do the cooling fan mod.
http://www.ls1camaro.net/sections.ph...ticle&artid=17
this is the write up on it.
Old Jun 17, 2005 | 11:13 AM
Jpr5690's Avatar
thanks, but ive seen a few writeups and am wondering why this wouldent work.... they all seem to hint at a problem with throwing codes bbut i dont see why... all im concerned with it is running the fans for max cooling without running into any pcm problems
Old Jun 17, 2005 | 11:40 AM
HBHRacing's Avatar
first there is no turning on high and low. It's an either or situation. Yes that will trip the high speed fans. However it will also set an SES. There is a reason that correct write ups are made and why there isn't one that is a simple ground switch.
Old Jun 17, 2005 | 12:05 PM
Jpr5690's Avatar
..why? ok how do i wire up the fans just to turn on hi .. also its my understanding there is a high speed fan and a low speed fan ??? if you turn them both on it will throw codes????
Old Jun 17, 2005 | 12:08 PM
Jpr5690's Avatar
are you saing that both fans run at either speed... or that thereas a low spped fan and a high speed fan
either way whats the simplest method for turning the fans on to the max cooling capasity...
Old Jun 17, 2005 | 12:18 PM
HBHRacing's Avatar
low = both fans on at low speed
high= both fans on at high speed
each fan isn't a different speed.
The way you have it it will trigger both fans to come on at high speed. But your still going to have ses codes from it.
Old Jun 17, 2005 | 02:00 PM
Jpr5690's Avatar
humm whats different about the slp switch and the writeups... do they use 2 individual grounds??? i cant see why it would though ????
BTW, thanks for the help... this issue though common has left me dead ended from searching
Old Jun 17, 2005 | 02:11 PM
HBHRacing's Avatar
without desecting an SLP switch I can't tell you. For obvious reasons I do not wish to disclose the methods that I use in the switches that I sell. I can tell you that you will get a code by just grounding the driver signals. this problem is why a lot of people with an OBDII system opt to buy a set up from a place that biulds them for the correct operation. you might in time find teh answer somewhere. But I can't be of much more help.
Old Jun 17, 2005 | 06:08 PM
Jpr5690's Avatar
ok well thats simpler than messing with it.... hbh how much for a switch with 2 leds that one orange lights up for low speed and a red and orange light up for highspeed delivered to daytona beach fl 32124
thanks,
john
Old Jun 17, 2005 | 06:09 PM
Jpr5690's Avatar
also do your switches require any soidering or cutting or are they plug n play?
