Speaker baffles/brackets L/R
Old Jun 22, 2005 | 03:34 PM
GPz1100's Avatar
Default Speaker baffles/brackets L/R
Is the left speakers bracket/baffle (in the doors), the same as the right?
I'll be making custom mounts, and need to know if I can just pull the pass door and use that as a template for both..
Thanks!
Old Jun 22, 2005 | 03:40 PM
badhoopty's Avatar
cant say on a camaro, but on a firebird its the same, but they are mirror opposites of each other.
Old Jun 22, 2005 | 04:30 PM
2FAST4U's Avatar
no there is a left and right!
Old Jun 22, 2005 | 04:33 PM
badhoopty's Avatar
unless i'm mistaken they are the same design and dimensions just mirror opposites...
Old Jun 22, 2005 | 04:42 PM
2MuchRiceMakesMeSick's Avatar
No you will need to use two templates.
Use the left for the left template and use the right for the right template.
They are marked with a 'L' and an 'R' if I remember correctly
Old Jun 22, 2005 | 05:23 PM
GPz1100's Avatar
So much for trying to save a step.
I'm going to use 1/4" MDF or plywood for the bracket. I want to mount the speaker from the bottom (or inside of the door). That should give some extra clearance between the grill and the woofer.
Old Jun 22, 2005 | 06:47 PM
2FAST4U's Avatar
Oh sorry, yeah you are right I just went to the garage and checked they are mirror. They are marked right and left. Butt if you are making templets doesn't matter. If you order stock ones there is a right and left.
Old Jun 22, 2005 | 07:50 PM
badhoopty's Avatar
heh...
all i can say is i used the passenger side as a template to make both my flat mdf baffles and they both fit fine. (although i guess i should explain i screwed the driver one on from the reverse side of the passenger.)
Old Jun 22, 2005 | 07:55 PM
GPz1100's Avatar
Very nice!
Is that 1/4" or 1/2" mdf?
You using nuts and bolts to hold it in place or just speed clips with sheet metal screws?
Got a pic of one with the speaker installed?
Thanks
