Diamond Audio 12" sub
Old Jul 13, 2005 | 06:01 PM
FLTransAm02's Avatar
Default Diamond Audio 12" sub
Will a DA 12 inch sub fit in the little cubby hole by my t-tops?
Old Jul 13, 2005 | 08:12 PM
BlkTARebel99's Avatar
It depends on which one you are looking at... the different models have different mounting depths... and if you don't mind losing your spare tire then the answer is yes.
Old Jul 13, 2005 | 10:12 PM
what does the little cubby hole have to do with the spare tire..
Cubby hole is on drivers side, spare is on passanger side...?
More comments welcome please guys!
Old Jul 14, 2005 | 04:23 PM
Theres gotta be someone with the knowledge here ?
Old Jul 14, 2005 | 04:40 PM
00PewterSS's Avatar
I made a fiberglass enclosure for that area and the most I could get out of it was 0.7cuft. I don't know of any 12" that is perfect for 0.7cuft, unless you want something on the small size of the specs. I have an IDQ12 in it and it is really punchy, it can't do low base in that small of a space.
Right now I'm trying to decide to go with a 10" in my box or just make a well box. There are several 10" that would work ok in that area.
Brian
Old Jul 14, 2005 | 10:23 PM
So I should say No to the 12 " sub in the stealth box?
Old Jul 15, 2005 | 12:59 PM
00PewterSS's Avatar
My opinion is no. I would go with a 10". As a matter of fact I'm switching my 12" out for a 10" and see how it sounds.
Brian
Old Jul 15, 2005 | 01:42 PM
Dal1as's Avatar
Go with a 10" Diamond sub in the stealth box. I have 900 watts rms going to an M6d2 of theres and it slams.
Here is my setup.
http://www.carstereo.com/installs/ph...&galleryid=753
Old Jul 17, 2005 | 05:11 PM
So your saying there is no way to do the 12" diamond audio?
Old Jul 17, 2005 | 06:28 PM
00PewterSS's Avatar
Sure you can do it. And if you prefer high bass that is most likely what you will get. You will not get the full low frequency response out of a box that is too small.
Brian
Old Jul 18, 2005 | 01:48 AM
Whats the difference between low frequency? and high bass? sorry im new to audio...
