Best radar detector?
Originally Posted by rwb
do a search, but it will come back V1.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I just went and priced a passport SR7 setup for the C6.
ready for this......$1,750 out the door. (dealer installation required)
here's a link if you wanna check it out: SR7
the system consists of remote sensors, front and rear, and jams laser. it is basically the passport 8500x50, remotely installed (in dash), and defeats laser, which is the lawless street-commando's biggest threat these days.
I'm currently sporting the passport 8500x50 which has saved my hiney more than enough times to offset the price, $325 if my memory serves me correctly.
I'm seeing more and more laser out on the highways. and once the detector let's you know you're getting hit with laser, you're already busted if you're speeding.
so it looks like some sort of laser-whacking system is in order if I'm to continue being a menace to the highways, which is my mission in life.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
here's a link everyone should check out when considering a radar detector. it gives you the straight poop on all popular models, what works and what doesn't. from $99 to $2,999.
RADAR TEST
RADAR TEST
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Board Certified Idiot
TheBest ones out are the Radars with Built In jammers. Check this out they actualy work and depending on where you live you can order yourself 1 ONLINE "COBRA ESCORT and VICTOR" BLOW A$$ chuNKS
Originally Posted by 2QuikTA
The question is how "well" does it jam laser. For the price, it better work flawlessly.
If you want something that works flawlessly against laser, there is a new unit out called the Laser Defender. We tested a prototype back in August (the AL6) and it blew away all of the competition, except with one laser gun. Word has it that that they've fixed the issue with the LTI, and that they'll be releasing the jammer in the US in the next couple of months. Assuming it works as well as their prototype did, it will be the best out there.
For more info check the liinks in my sig.
Ungrounded Moderator
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
This is a subject that has been beaten to death as well but RADAR JAMMERS DON'T WORK! and even if they did they would be illegal to make, sell, or use under federal law since they would have to transmit in the microwave frequency range which is controlled by the FCC.
Laser jammers are a different thing. Since they use light rather than radio waves they aren't restricted by federal law (although a couple of states have made them illegal). They can be very effective when properly designed, installed, and used. In other words, don't go blasting by a cop just because you have laser jamming - the jamming is only effective at a certain distance and once you get close enough they will still get a reading.
