Autometer A/F Gauge
sell. the come with a pigtail already installed so you dont cut into the wiring. try LMperformance.com
i'll see if i can find you a link. one thing to remember, the gauge is supposed to "dance" since the 02's are constantly adjusting themselves, so dont be alarmed if you see it hit rich, then back off alot then back to rich again real fast..
i also hope you put this on one of your FRONT O2 sensors and not your rear
you need to tap into the wire that goes back to the PCM.
the gauge itself is, and narrow band readings, are not accurate to say the least. Just because you see it pegged at WOT, doesnt mean there is a problem... its better than being lean at WOT
anyways.. if its showing rich.. it could be at anything less than 14.7 on a wide band reader. you should be at about 12-11 going WOT.. and around 14.7 while at idle.. using that sensor is not going to accurately show you where you are, for that you need an LM1 or wideband equivalent.
i would say you are fine, as long as you are not seeing stoich or lean while doing WOT runs, mine did the same thing, i took mine out because it really didnt do anything for me. for tuning purposes i use my LM1
you have to drill a hole in your Y pipe, weld in the bung, put the wide band sensor in, then run the wire from the O2 sensor, into the cabin using the window..(this is not ment to be a permanent fixture in the car, just for tuning) the hand held unit has a digital read out, and reads in real time, you can also record with it, for playback.
so if you tune your own car, then its a must have. if you take it to a tuner, they use this type (or damn well should be using it) of system.
