Removing the door panels
I hate broken clips
, and when things dont re-install as they were originally. So I was wondering exactly how the process goes, and what to watch out for.Thanks.
I hate broken clips
remove all screws
completely remove window switch panel and inside door handle bezel
then push up a little and it comes right off
no litt clips to break!
atleast my 98 didnt have any
just follow the removal part. It has pics and all. The Camaro door is very close to the same.
In this cold the plastic gets pretty brittle... ever notice the door handle trim rings selling for $30 on eBay?
Brandon
Pry the switch housing out from the top not the back. The plastic is thinner there. I cracked a piece off when I used the back part. Super glue fixed it though and you cant see it unless you really look hard.
When putting it back on make sure you have the bottom tabs in before the top.
