Maptech/humount.com question
Old Mar 7, 2006 | 04:11 PM
jsturdivant's Avatar
Default Maptech/humount.com question
Anyone with a Maptech/humount.com HU mount. What wire did you tap to get power? I'm looking to see if there is a way to only light the mount when the headlights are on.
Old Mar 7, 2006 | 04:50 PM
NufNuffZ28's Avatar
I taped into the lighting on the HVAC so that it is only on when the lights are on
Chris
Old Mar 7, 2006 | 05:09 PM
umrjmac's Avatar
I think that I used the dimmer control wire on the head unit wiring harness
Old Mar 7, 2006 | 05:10 PM
peterlawl84's Avatar
i cant remember which one i used, but i just followed the directions that came with the faceplate and it only comes on when the headlights are on.
Old Mar 7, 2006 | 05:48 PM
nikeboy313's Avatar
i did not recieve a set of instructions when i got mine... so thanks for posting this thread because i have not thought the far ahead. i will be installing this when i get home from school for spring break. so thanks for the heads up what wires to run the power off of
Old Mar 7, 2006 | 05:53 PM
RollTideTA's Avatar
I used the dimmer wire, the wires in the new wiring harness for the aftermarket radio were labeled.
You can download the instructions from their site: http://www.maptechenterprises.com/hu...in-install.htm
Old Mar 7, 2006 | 06:31 PM
Xtremespeed's Avatar
The gray wire in the factory harness will have power when the lights are on. The brown wire will too, but you can control it with the dimmer switch. If you buy an adapter harness, the wires should be orange, and orange with a white stripe.
Old Mar 7, 2006 | 06:47 PM
ProjectCamaro's Avatar
That's what I did with mine, it comes with instructions on which one to tap into.
Old Mar 7, 2006 | 08:13 PM
LawmanSS's Avatar
I moved this here...you should have better luck in this forum.
Old Mar 7, 2006 | 10:25 PM
max5's Avatar
I didnt realize this many people had this, lets see some pics!
Old Mar 7, 2006 | 11:34 PM
nikeboy313's Avatar
according to the posted directions you are supposed to have a red piece that goes over the LED's, i did not recieve this or instructions.. maybe i just didnt pull them out of the box. i hope that's not the case because i already threw the box away...
Old Mar 8, 2006 | 01:48 PM
Wow, lots of replies. I think what is going on is that recently maptech started sending out a lot of units pre-assembled. I guess when that happened they stopped putting in the instructions. That's why half of the guys just getting the mounts in look like lazy idiots. Thanks to everyone for the help. Dimmer wire it is.
Nikeboy, I think that the red lense is only if you have the bulb set up and want it to be red, if you have LEDs or want another color, you don't need it. At least my blue lettering didn't.
Pics of my entire install are coming.
