Need Help No Bumps
Old Mar 20, 2006 | 09:55 PM
98whitez28's Avatar
Default Need Help No Bumps
i just installed a jl audio wedge box with 3 jl 10 wired to get a 4 ohm load. powering them is a kicker kx 500.2 that is bridged. i am still running the stock deck for now. i got a line output converter but i hooked it up to the rear speakers and i am not getting any bump from the subs. do i need to move the loc to directly behind the head unit? and if so which wires do i need to splice into? do i need to ground the loc with using this amp? i am using a audiolink powerlink 2. do i need to get a different loc? any input is greatly appreciated.
Old Mar 22, 2006 | 04:11 PM
ded71's Avatar
I have never used line converters, so just a thought. The sub bass in a monsoon system (I'm assuming you have this) only goes to the sail panel speakers, so hooking the converters to the rears won't give you much "bump".
I think they need to be in line with the sail panel speakers, but you should probably connect them before the monsoon amp, as I don't think your new amp will like getting a signal from the monsoon.
Again, just trying to help out, I have never used them. Good luck.
Just a thought, a new head unit would be a great solution. Much better sound quality, and then you can off those line converters, and just use straight RCAs. There are decent units out there that aren't too expensive, and the install is a snap. JMO.
Old Mar 22, 2006 | 05:24 PM
todddchi's Avatar
ded's right. If you tapped off of the hatch speakers they got no bass man!
Tap into the rear INPUT side of the monsoon amp, or the deck rear speaker outputs. Dat's the ticket man. No issue with doing it at the amp harness, it'll be fine.
Old Mar 22, 2006 | 08:34 PM
98whitez28's Avatar
thanks guys but i got it to work and it was hitting hard then nothing. took it to get bench tested and the rca inputs took a dump.
Old Mar 22, 2006 | 11:49 PM
SlowBurn's Avatar
If you're going to go all out like that, I can't recommend an aftermarket cd player enough. For as cheap as they are, you'll be a LOT happier than dealing with the stock deck.. You can get an Alpine 9853 for around $250 and it will do everything you could want and more.
Old Mar 23, 2006 | 07:09 AM
WhiteBird00's Avatar
Ungrounded Moderator
It'll do everything except fill up the opening and look stock...
Old Mar 23, 2006 | 12:35 PM
evilbadz's Avatar
Why would you want a radio that looks like the stocker? Especially with 10s and everything else visible in back.
Old Mar 23, 2006 | 12:49 PM
For those of us who don't have audio equipment all over that is visible from outside, there are several reasons. The primary ones are theft deterrent (nobody's going to bother with the stock stereo) and not looking like it was added on. Many aftermarket radios look like kid's video games and very few of them look like they actually belong in the dash (no matter what install kit you use).
Old Mar 23, 2006 | 02:51 PM
98whitez28's Avatar
im going to put a deck in but i am waiting to buy a house. like he said its more of a theft thing. people look inside see the stock deck and assume screw it this thing doesnt have anything. or at least thats what im hoping.
