new subs/amp/hu problem
Old Apr 2, 2006 | 10:59 AM
slik98z's Avatar
Default new subs/amp/hu problem
I just recently replaced all of my speakers, and just got my new head unit this week and installed the apline head unit and 2 alpine 10 inch subs with an alpine 900 watt 2 channel amp.
i got everything in, head unit works great, the 4 new alpine speakers sound great as well, however my amp lights up but the subs are not being powered.
everything seems good with the wiring, even the ground seems to be good. just no power to the subs.
im trying to trouble shoot this to see what the problem but i dunno where to start.
everything is brand spanking new, just a few days old.
any input, opinions, or ideas would be very appreciated.
Travis
Old Apr 2, 2006 | 01:51 PM
WantedRawb's Avatar
check the gains on the amp make sure you dont have them at 0... then check the RCA's i doubt its a blown amp but could be...
Old Apr 2, 2006 | 02:17 PM
Quick6GN's Avatar
Do you have the monsoon system? I had the same problem with my 98, Eventhough the new head unit is using an RCA output to your amp for some reason the Monsoon factory amps kill the signal output? I've been doing 12v installation for a living for 17 years and never saw this issue until recently. I had to bypass facory amps in order to get sufficient signal voltage to my sub amp. If u dont have the Monsoon system then ignore the above and check the inputs on thamp it may sound silly but i've seen issues with imporper gai setting or accidentaly plugging into the output rca side of the amp.
Old Apr 2, 2006 | 03:20 PM
slik98z's Avatar
yeah i gotcha on that one but i dont have the monsoon system anymore. its all new stuff wired directly to my head unit.
where i have the rcas from my head unit it reads "INPUT" in big letters so ik now thats in the right spot. ill check the gain but i remember fiddling with that to see if that was the issue and didn't get anything. im gonna go pick up some new rca cables to see if that will help.
Thanks fellas
Travis
Old Apr 2, 2006 | 04:38 PM
Charlie Hustle's Avatar
Thanks fellas
Travis
when you say "input" in big letters, that is on the amp correct? also check your ground again. i just installed a system and the amp wouldnt power the sub, turns out the ground was in a bad spot and kept coming loose. make sure you scrape the paint off of the body where you decide to ground the amp. hope this helps
Old Apr 2, 2006 | 04:41 PM
peterlawl84's Avatar
if you are talking about it saying "input" coming from the HU then thats your problem. You need to plug in the RCAs into the "output" plugins from the headunit and into the "input" of the amp.
Old Apr 2, 2006 | 10:51 PM
slik98z's Avatar
its from the output on the head unit an dinto the input of the amp. this is my 17th set up i've done, ive never had issues before with new items, i have had it with used though. so this is a first.
the metal was sanded down for the ground and i used a self tapping screw for it. and its solid. the light on the amp never flickers its always on once the car is on and the head unit is.
i have already tried changing the wiring to the subs and it changed nothing. the gain didnt hchange anything so im gonna try the rcas. after that i think ill try the amp. the head unit works so well with the other speakers i just dont forsee how it could be the head unit
Old Apr 2, 2006 | 11:09 PM
sexyvic1's Avatar
1 - check the RCA's for sure...if u have a continuity tester u can do it like that.
2 - go through the radios menus and see if u have to turn on the sub option for the rca's to work...some radios have that not sure if yours does.
3- i am not be littling u but make sure the subs are conected in the box, sometimes u overlook stupid thing...u know.
oh and do the 2nd thing i wrote first since it is the easiest.
Goodluck
Old Apr 3, 2006 | 02:19 PM
LS1Zedder's Avatar
I have a couple alpine decks. One has 3 sets of RCA's in the back and the other two. On the one with 2 sets, you have to choose either Subwoofer output or rear speaker stereo outputs. That may be your problem. Even if you have 3 sets of outputs the sub ones might be turned off. Although I think the default settings are Subwoofer on.
Old Apr 3, 2006 | 03:59 PM
slik98z's Avatar
yup u were right. i replaced the wiring kit (free of charge by the local shop) and that didnt change anything, i left kind of ready to give up and just take all the stuff back.
on my break at work today i ran out and just looked through the menus and figured out that i did have to select to turn on the subwoofer outputs. turned it on and no sooner did i do that and the mirrors were shaking.
i just gotta do some fine tuning now, but thanks for all the help everyone!
Travis
