Autometer help! PLEASE HELP!
Old May 10, 2006 | 10:59 AM
BlackBirdWs6Zzz's Avatar
Default Autometer help! PLEASE HELP!
Ok I have a 5" tach. I need to know where you guys hooked up the power and where you hooked up the ground. I have a LT1, which wire to I tap in for the RPM's.
I need to know a 12v power source that isn't on 24/7, just something that comes on with the ignition or light switch!
NEED RECOMMENDATIONS QUICKLY THANKS
ANY PICTURES OR WRITE UPS WOULD BE GREAT! MAYBE EVEN A SCAN OF THE DIRECTIONS TO HOOK UP! I bought it used!
!Josh
Old May 10, 2006 | 11:46 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Pull the cover off the fuse access panel inside the car. Hook the red wire up to the ignition fuse and the white wire up to the headlight fuse. As for the ground you can use any factory ground inside the car. Sorry but I can't help ya on the tach lead wire for the LT1s.
Old May 10, 2006 | 11:51 AM
You are AWESOME! Thank you.
Old May 10, 2006 | 11:57 AM
carrsls1_camaro's Avatar
Where would you hook up tach lead for a LS1 car?
Old May 10, 2006 | 12:33 PM
you would have to tap into the RPM wire but I think ti's a different color on the LS1.....wish i could help you!
Old May 10, 2006 | 12:58 PM
daryl2cb@yahoo.com's Avatar
go to a dealer and get a computer sycematic, it would have the labels for the pins outs on the cpu.
Old May 10, 2006 | 01:24 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
www.autometer.com is a good place to start.
Moving this to the wiring and electronic section.
Old May 11, 2006 | 12:13 PM
Ok sooooooo...........Some guy who had an LT1 told me it's the white wire under the passenger kick panel.........here is what happened.
so I tried to tap the RPM wire, which you said was white, but I did it and it didn't work, then I realized as I was connecting it off and on, my interior lights were going off and on. hahaha. so I was like hey i'll try to white one with the black strip. (WRONG) Then my security light came on and wouldn't let me start my car, I locked the doors, alarm set, then I opened the doors, teh alarm went off (usually i turn it off by putting the key it and putting it on the ON position, but that didnt work. It went for about 3 mintues and shut off, then it let me start it again (PHEW)
So i have determined it's not the white or white with the black stripe. Any other suggestions...I scared now to just tap wires now.
