Tweets in the a-pillars...not good.
Old May 12, 2006 | 05:16 PM
99blancoSS's Avatar
Default Tweets in the a-pillars...not good.
Been on the final stages of my audio upgrade and trying different locations for the tweets. With the x-over set on flat for the tweet there is no way they can sit on the a-pillar anywhere. Its waaaaaaay to bright with the tweets up there. The best location seems to be in the kicks. I can flush mount the tweets alone in the kicks and it sounds much much better. Not sure how you guys with tweets up there put up with it. They must be tuned way down.
Old May 12, 2006 | 06:51 PM
jrnorman's Avatar
You are right! I thought I was the only one. I put in some Alpine components in the front along with a new amp and all new two ways in the back and sailpanels. I tried all sorts of locations high and none sounded as good as mounted just above the 6 1/2 speakers in the door. I was pleasantly surprised that it was fairly well balanced left to right and not overly bright like you said. These tweeters seem to be more omni directional than I thought they would be plus you can adjust the angle slightly.
Old May 12, 2006 | 09:07 PM
Snootch's Avatar
Usually the closer the tweet is to the mid, the more defined the soundstage. However, there are exceptions. The reason I have my tweets at the bottom of the A-pillars, is because every time I shift, my left knee was blocking the driver's tweeter as I worked the clutch. I mounted the tweet low in the a-pillar, turned the eq down, and played with the crossover point. It works rather well now. If you can mount your tweets in the kick panel, I say go for it. Before making permanent mounts for it though, I would use some double-stick foam tape, and try different locations and angles for the best sound.
Old May 12, 2006 | 09:25 PM
99blancoSS's Avatar
Thats where I'm at. Using the tape to see where it sounds best.
Old Jul 17, 2007 | 01:38 PM
JasonWW's Avatar
Tweeter location is more about imaging and staging. If they are too loud by the a-pillar, simply reduce their volume level. It's ultimately up to the listner, though. If you like them in the door, then that's fine.
Old Jul 17, 2007 | 02:49 PM
99blancoSS's Avatar
Well I went back to the a-pillar but I'm going to the front of it by the windshield.
Old Jul 17, 2007 | 11:50 PM
camcamaro1991's Avatar
Question A different local
hey i havnt got my Kappas compo... system yet but i was planning on putting
them behind the a-pillar defrost vents( the vents are worthless to me down here in TX ), and then adjust levels for balance.,
i dont like the idea of cutting holes in my panels for a set of tweeters.
just my 2 cents i will get pics hopefully but this weekend. speakers are in transit.
camcamaro1991
Old Jul 18, 2007 | 12:21 AM
99blancoSS's Avatar
I've seen them in there and they look good but for me it justr seems like it to much in my face. I've got extra a-pillars just in case I hose them..lol
Old Jul 18, 2007 | 05:41 PM
Jeff 97 Formula's Avatar
I have my tweeters from my Kenwood set (KFC-P603) on my a-pillars and quite frankly, they sound the best there. I tried all locations (on the dash under the windshield, on the doors, near the mids, etc) and they just didn't seem very effective. My Formula does not have the upgraded stereo from the factory so there are no tweeters on the doors.
Old Jul 18, 2007 | 10:19 PM
Default Just in, right out the box Kappa's
hey i just got these off the UPS truck
2 sets of 6 1/2 infinity kappa 60.7cs components, although i am only going to use 2 cross overs and i am only goint to use 1 set of the tweeters.
now i just need to wire them in.
still waiting for more speakers to come in.
kappa 4x6's are in transit for the very back side panels in the rear.
Old Jul 19, 2007 | 12:01 PM
3.4camaro's Avatar
I ran my a-pillar tweets off the headunit and amped my doorspeakers, so they are louder. Sounds badass.
Old Jul 19, 2007 | 05:10 PM
Richiec77's Avatar
Yeah. Every 1" distance from the center is a 180 deg phase shift and corresponding time lag. Usually the closer the speakers are together, the better the stage will be. But alot of times the stage is low since the speakers are low. That is why sometimes you have to seperate the tweeter and move them to the A-Pillers to bring the stage height upwards.
You can also do the same thing by placing some cheaper tweeters up high to compliment the Component set, but you usually need to play them pretty soft and low and usually set the X-over points much higher so it's more transparent. Mine was a 30 ohm resister and X-over point was set about 8.4 kHz. Helped to bring the stage back up while the tweeters are still mounted low in the kicks. Powered them off the deck.
I can't wait to get back from all my traveling and do up a really nice systems.
Old Jul 21, 2007 | 11:10 PM
Carlos01SS's Avatar
I got the Infinity KappaPerfect 6.5 components in the front and the 6.5 subs only in the sail panel area, and a 10" type R sub, my friends are absolutely floored at the sound quality, I'm pretty shocked and impressed as well...
Pic of the installed tweeter pods, kinda blurry, but you get the idea.
Old Jul 22, 2007 | 12:13 AM
ultraz's Avatar
didnt snootch make those?
Old Jul 22, 2007 | 12:41 AM
Carlos01SS's Avatar
I got them from a a member in this site, I forgot who he was though...
I can find out if you're interested...
Old Jul 22, 2007 | 12:51 AM
Richiec77's Avatar
Those are mounted in the front Sail's not the A-Pillars. If you mounted them in the actual A-pillar, you can bring the stage more forward and up a little more. Mounted in the sails isn't a bad spot and it's a much easier install. But if you ever want a little more from your sound stage, mounting them more forward with help even more. You can also bounce them off the windshield for even more flexibility in tweaking the stage.
Old Jul 22, 2007 | 08:37 AM
2MuchRiceMakesMeSick's Avatar
Put em in the kick panel if you want better imaging. I also mount another set behind the rear view mirror (facing towards the window) in combination with a midbass center channel for good imaging.
Old Jul 22, 2007 | 10:07 AM
Carlos01SS's Avatar
I'd like to see some pics of tweeters on the A-pillars...Pardon my ignorance, but is the A-pillar the part where the sides of the windshield rest on?
Old Jul 22, 2007 | 07:07 PM
JasonWW's Avatar
More A-pillar mounting info here.
https://ls1tech.com/forums/wiring-stereo-electronics/439229-tweeter-mounting.html
Your leaving out one important thing.
"Usually the closer the speakers are horizontally together, the better the stage will be."
Meaning that the left side speakers image better when mounted vertically one on top of the other. Same for the right side. Our ears can hear very minute differences left to right, but are very bad in pinpointing sounds up and down. So you can mount the tweets much higher than the mids and as long as the left to right distance is small it will be hard to impossible to tell they are so far apart from one another.
Are you talking about the tweeters only? That doesn't sound right, but I can't remember off hand how it's measured.
Old Jul 22, 2007 | 08:22 PM
2000Z28ls1's Avatar
I didnt want to drill into anything so I took my alpine R component tweeters and veclrowed them next to the a Pillar on the dash facing inward toward teh center of the car
