turn signal out
One is for the left/right signals,
The other one is for the hazards.
If one side works and the other doesnt, then there is nothing wrong with the flasher.
Turn on the hazards and look for the bulb that either isnt flashing, flashing erratically, or not lit at all. That will be the culprit. The front and rear turnsignals are dual filament. The dim fiament is for the "parking" lights and the brighter filament is for brake lights and signals.
Once you've found the offending bulb inspect its socket. Either the socket has corroded or the bulb has blown.
The rear left turn signal works.
The rear right turn signal will illuminate, but will not click.
When hazards are on, both rear lights will flash.
The front right turn signal is out, and will not work with hazards. The front left does work.
The front right light will work with foglights and/or low beams on.
The front right light will not work as DRL, the front left does.
Could this be why the turn signal does not work?
If the left side doesn't flash then double check all the bulbs including the side markers for one that's burned out. Don't forget that there should be two bulbs for the turn signals and brakes on each side.
If neither side flashes after checking/replacing the bulbs then the flasher is the likely cause of the problem.
Yeah, go on and have it replaced(socket), or you will constatly have a problem with the bulbs going out.
http://kalecoauto.com/index.php?main...&products_id=6
I went to Advanced Autoparts and bought a new socket. I wired it up and attemped to put the bulbs in, which fit the OEM, and they did not fit.
So, I went back and bought the bulbs that fit the new socket, matching the number on the back of the box. I put the bulb in and they made contact. I tested and it blinked. But, the bulb would not twist in to lock in place so it would not stay in. At this point, I said **** it. I decided I was going to go buy GM and use the aftermarket until I do so I can drive my car. I figured since the socket sits up right it will be alright temporarily. Nope. The notches on the socket are off about 4 cm so they won't fit the lamp! This aftermarket **** sucks! But what do I expect for $6. This **** pissed me off, it's a damn light socket change and it's this big of a deal. http://kalecoauto.com/index.php?main...&products_id=6
no im pretty sure they checked that on my last oil change.
j/k, this sucks, well it works now so i'll just wait. sucks i am being punished for using my blinker too much. you know like a good driver and all
