Air/fuel ratio install help!!
Old Jun 28, 2006 | 01:35 PM
Kmoore's Avatar
Default Air/fuel ratio install help!!
Just installed the power and the ground, now the purple one where on the PCM? Is a 2001 camaro z28, and by the way is a C2 gauge
thankyou
Old Jun 28, 2006 | 01:38 PM
J-WS6's Avatar
the purple wire needs to hook up to your o2 sensor.
Old Jun 28, 2006 | 01:53 PM
Duffster's Avatar
onto the purple wire of the o2 sensor
Old Jun 28, 2006 | 02:21 PM
Kmoore's Avatar
OH OH where is the o2 sensor , Im sorry Im just got the car recently
Old Jun 28, 2006 | 02:31 PM
flash12t's Avatar
not sure the year but on my 2002 ta its on the top pcm and i think its #24 pin its a purple one.
Old Jun 28, 2006 | 02:43 PM
Kmoore's Avatar
Pin#24, same TA and camaros 2001 and up?
Old Jun 28, 2006 | 04:30 PM
flash12t's Avatar
my bad its pin #65 & #66 http://www.ls2.com/boggs/torques/00pinpcm.htm
and make sure u get a good connection it took me forever to firgure out why it wasnt working. .
Old Jun 28, 2006 | 05:19 PM
Kmoore's Avatar
Thanx sorry man wich one should I use or both , really sorry the gauge has only 1 purple wire, then red and black for power and ground
Old Jun 28, 2006 | 08:33 PM
Kmoore's Avatar
K Im done installing it, now does the C2 air/fuel gauge supposed to light blue like the other C2's? or just the lean/rich lights
Old Jun 28, 2006 | 09:20 PM
Kmoore's Avatar
PLEASE people , the thing doesnt work very good, is it the pin #65, #66 or the #69? for a 2001 Z28 camaro
Old Jun 29, 2006 | 07:34 PM
flash12t's Avatar
i used # 66 cuz 65 was giving me shitty readings. . u just have to make sure that ur getting a good connection. . also u have to allow the 02 sensor to heat up take it around the block or for a ride. .it should bounce from lean to rich and go rich at full thottle .. . . . --LED lighting of just the readout, not the whole gauge. (Lean - Rich) Works with most OEM and aftermarket oxygen sensors, if sensor is needed--
Old Jun 29, 2006 | 07:35 PM
flash12t's Avatar
pm me if u need any more help
Old Jun 29, 2006 | 07:51 PM
Kmoore's Avatar
Thanx a lot, finally got it, I used the #69 pin cuz I tried 65 and was weird , so this one seems to be working fine, thanx I tought people were not going to answer
Old Jun 29, 2006 | 11:47 PM
sping012's Avatar
The one that lights up, will have another wire you hook to a power source, you have just the read display Gauge, which will only light up the lean/rich LED's
