What can I get away with?
FOR SURE I WILL BE USING:
Alpine cde 9852 with the ipod cord KCE 422i
alpine type r 6.5 coaxal speakers, door and sail panel
alpine type s 4" coaxal speaker, rear hatch for fill
These will be run by a mrp f450 400 watt amp
AND MAYBE an Alpine type r 10 in a stealth box run off mrp m650
OR 2 driver and passenger stealth box type r 10 run off a mrd m1005
I will not run an additional battery as i plan on dd this car and making trips to the track on weekends. I will upgrade the alternator if i have to. So my questions are:
Can i get away with running 1400 watts off the stock alt and a single bat?
Can i get away with running 1400 watts off a bigger alt and a single bat?
Can i get away with running 1000 watts off the stock alt and a single bat?
Can i get away with running 1000 watts off a bigger alt and a single bat?
Thanks for your help.
Brandon
You would probably want your total fuse rating on the amps to be under 100-120 amps with full stock.
I was thinking the driver side stealth would be fine but I'm not sure if I can run both subs. I have read the FAQ's and it seems I would need something like a 190 amp alt. I think I'll just keep it to one until I get the money to buy a new alt.
Any pics of tweet installs in camaros?
Anything wrong with the above?
oh yeah, and you can't let the yellowtop get low, or you can literally kill the alternator in one session...
unregulated = more power in, more power out (such as 100w x 2 @12.5v, 150w x 2 @14.4v)
regulated = same output, regardless of power input (such as 100w x 2 @ 10.5v - 14.4v)
also, you will likely be better off getting a single amp with 5 or 6 channels...4 channels for the front/rear speakers, and either the 5th channel or channels 5 & 6 bridged to drive the sub(s). that way, you only require a single power, ground, and remote turn-on wire, which will make installation a whole lot easier.
ditch the rear hatch speakers....you don't need them if you go with full-range speakers in the sail panels
Where do you guys put your tweeters?
