whining sound in stereo when accelerating?
when i first did my system i ran my rca's to my headunit and my power wire right next to each other and it sounded like my rear end gears were whining. then i seperated the wires and no probs since
It may or may not be related to the factory amp.
take it back to the shop and tell them to fix it. There is no excuse for a professional installer to let a car leave the shop like that. And if they tell you that you need a ground loop isolater, ask them to pin point which piece of gear is causing the noise. If they cannot answer that, then take your car and leave, as they don't know any more then an average shade tree installer...
I was pretty sure they disconnected the stock monsoon amp so I am thinking it is a ground loop like mike had mentioned. I will give them a call and see what they say.
not necesarily... It's an 'urban myth' if you will of car audio. It may happen in 1% or so of all cases. But for the most part, it does not cause noise, especially not alternator whine.
in my experience, I'd say 50% of all alternator whine isses has to deal with the ground wire in the factory harness not sufficient for an aftermarkey head unit. Grounding the head unit right to the chassis solved the problem.
mike
mike
i will have to try this, ive never heard of it before. i ran all new wires to all my speakers, and i still have a whine. ive tried 2 different "ground loop isolators" and niether worked worth a damn. i will let you all know what happens after i ground the headunit to the the chassis
mike
