Turn signal indicator light problem
TIA.
The problem is caused by a burned out bulb or corroded socket on the side that doesn't flash. Turn on your hazard flashers and then walk around the car looking for the bulb that doesn't flash. It will probably be the front one because they often get water in them. Replace the bulb and check that the socket isn't corroded (otherwise clean or replace it).
TIA.
Okay, as I said the indicator lights are wired parallel to the exterior turn signals so there is no real connection between them and the headlights. It would be a possibility that the ground connection for the lamps is disconnected forcing other lamps to backfeed through the signal indicator lamp for ground. However, this seems unlikely because there would be other symptoms such as the turn signal indicator lighting when the seat belt reminder light was on (same ground path). Are your DRLs working properly? If the power is backfeeding through the indicator light it would ground through the DRLs via the DRL module.
Does the indicator light go on with just the headlights or any time the dash lights are on (parking lights)? Does the brightness of the indicator light vary with the use of the dimmer switch? For that matter, do the dash lights still dim properly?
Also, are you sure the indicator bulb is lighting rather than it just picking up stray light from a nearby bulb? That could indicate some damage to the instrument cluster backplane. Have you worked back there recently (new gauge overlay perhaps)?
Sorry for so many questions but I'm just trying to get a handle on what might cause your problem and need to eliminate some possibilities.
Anyway,
The indicator turns on with parking lights only as well as with headlights. The dimmer switch still works but does not dim the indicator even if turned all the way down.
What are DRLs?
If the light still illuminates, replace the fuse and try the same thing with the TAIL LPS fuse (#5) and the IP DIMMER fuse (#16). Once we determine where the power is coming from we might be able find the fault.
I'll have to wait till it returns.Thanks for all your help.
