distribution block will it need fuses?
should this block be fused or is the big fuse close to battery good enought protection?
only planning 2 amps not sure about other stuff like a capsistor ?if I get a capasistor will it connect though one of these blocks?
http://www.cardomain.com/item/STISTEE4PT
using 4 guage so I'll need 4 guage to 4 guage right?
Thanks
Blacker thanks for advice haven't gotten advice from you in a while, couple years back on LS1 value you're advice .
This car is almost done /mods aduio will be the end untill I mile it up.
second planned amp JBL 104X4 RMS powering door separates & sail panel separates.
http://www.crutchfield.com/S-ArcibaU...&display=L#Tab
Stock alternater .
see the holes in side of amp I'm thinking these are for air so in litemup02 install (looks good)
it appears to have the holes covered will ruein the amp?
Thanks
Then i'd use another fuseless block for your ground like this: http://www.knukonceptz.com/productDe...prodID=BC-1448
You can connect your cap to your main 4Ga wire between the battery and distro block:
Hope I could help.
Hope I could help.
http://www.onlinecarstereo.com/CarA...ProductID=16956
http://www.onlinecarstereo.com/CarAu...roductID=16956
not sure of how much current it draws but seams to be a good idea to fuse the distrobution block.
so don't get a 4guage in an 4 guage out 4 & 8 out?
as far as a distrobution block for the grounds seams unnessesary can't I just come out of each amp to the body I mean ground is ground right? plus none of this stuff will be visable.
Lastly I was lead to beleive a cap won't be nessesary / this relatively mild power sys. ?
Thanks guys for advice I'm almost done / audio
Also, both amps would need 8 gauge and the 4/8 gauge will work fine. You also have 4 outputs to expand from, if need be.
A capacitor is not nessecary unless you have light dimming problems. After you install the system, hammer on the system at full volume at night with the car idling and the lights on. If the headlights and dash lighting dim noticeably when the bass hits, and your voltage gauge dips below 10v, then you will want to purchase a high output alternator to fix this problem. After a few months you can burn out the diodes on your stock alternator by drawing too much current through it.
If your headlights just barely dim when the bass hits, and your voltage gauge barely moves (or doesn't) then a 1 Farad capacitor will solve your problem. As said before, a cap is basically a band-aid for minor voltage dips. anything more serious than that really requires a high output alternator. (unless you like replacing alternators every few months.
) Last edited by Snootch; Aug 8, 2006 at 09:08 AM.
what would be a good upgrade? Can I rebuild the orginal? there's not to much to alternater right?
I don't drive much at night do'es this voltage dipping only occur when lights are on or even / AC on?
Thanks for sound advice.
