Anyone use this digital guage?
Here's a link to the site
http://www.aeroforcetech.com/index.html
Duff
Displays functions including: RPM, MPH, intake air temp, mass air flow, engine coolant temp, injector pulse width, fuel trim, manifold pressure, ignition advance, knock retard, engine run time, battery voltage, trans temp, oil pressure and more.
The main website says IT DOES clear SES codes in addition to displaying them..
Another list of functions:
Example Parameters
Engine RPM
MPH
Knock Retard
Intake Air Temperature
Mass Air Flow Sensor Frequency
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width (bank 1 and 2 if supported)
Long Term Fuel Trim (bank 1 and 2 if supported)
Short Term Fuel Trim (bank 1 and 2 if supported)
O2 Sensor Voltage (bank 1 and 2 if supported)
Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
Ignition Advance
Knock Retard
Engine Run Time
Battery Voltage
Transmission Temperature
Idle air Control Counts
Throttle Position Percentage
Throttle Position Voltage
Engine Load
Oil pressure (this feature available for some 8 cyl engines only)
http://www.pfyc.com/store/merchant.m...ct_Code=GN2110
I have just been reading about this gauge for the last hour on here. I did a search and everyone that has one loves it. I am most likely ordering one tomorrow. I did read several times that it does NOT read oil pressure on LS1's. Since the stock oil pressure gauge is functional the Interceptor will not read oil pressure. It reads just about everything else though.
I'd heard from a mechanic friend of mine that the oil pressure wont read...thats why I asked earlier for a list of what it will/won't read for certain, not what it 'could'
