Confused.. iPod hardwire to 98 Monsoon.
I have searched and read through some posts regarding hardwiring an iPod to a 98 Monsoon unit and I'm still confused. What is the best/cost effective way to hardwire my iPod to my Monsoon unit? Can I splice an RCA in there? (I know this wont charge it, obviously charging it would be great but not a nessecity) What are my options.. if you have links to products please dont hesitate to post. (I also have a FM unit for it, but I honestly don't like it too much.
the GM9-AUX unit is $60-100 bucks i think
and there is an iPod2Car that plugs into the GM9-AUX wiring harness
basically the GM9-AUX harness plugs into your CD changer input in the back of your head unit... and then you get either the iPod2Car adapter or the GM9-AUX - to - RCA adapter.
the iPod2Car is over $100.
Ungrounded Moderator
That's correct - none of those auxiliary or iPod adapters will work with a CD head unit prior to mid-99. They work with all cassette head units but only CD HUs from late-99 or newer models.
Without replacing the head unit your best option is a hard-wired FM modulator. They give much better performance with less interference than the wireless ones. Be sure to get a good one - the cheap ones don't cut off interfering local FM stations.
Originally Posted by WhiteBird00
Yeah, sure...on your 2000 it will work fine but not on his 98.
Originally Posted by Mike02Z
USA Spec makes one for the 98-02 Fbody. Just put one in. It was 139 but I'm sure you can find it cheaper. It also added an extra input. You can't ths and the factory changer but since I didn't have the factory changer it was no big deal to me.
