How Can I Rewire Fog Lights To Come On When I Want Them To??
Ok i have a regular trans am and if i want my fog lights on then i have to turn the little **** and the flip up lights come up but on the ram air they have it where only the fog lights will come on and not the flip ups, how can i hook mine up where they willl do this?? with the stock wiring??
Copy & Paste Moderator
I have a Formula and I can have my fog lights on without the headlights being up. The first position on the **** is "parking lights". In that position, Fog Lights, DRLs and side markers are on with the headlights down. This is how it works stock on my car.
when you turn the **** once the headlights pop up but the actual headlights do not come on and the fog lights come on then, but i dont want my actual headlights doors to come up when i do turn the know once i just want the fog lights on but ive already got help with it the website that guy gave me will work im going to try it out when i actually get time..
the first postion is only running lights, the headlights should not even flip up. i think you have another problem, maybe with the headlight motors. but the headlights should not come on or flip up with the first position.
Yeah, I had this problem when I bought my formula, only my passenger side headlight was grinding as well. I have heard that even without the grinding, this is a common problem. You need to rotate the headlight motor gear on at least one of your headlights 180* as the teeth are getting worn and the auto-adjustment is not working. I will look for the thread I used and post up a link later tonight.
Nick
Nick
Yeah you're car does the same **** as mine.
Its not normal.
The popup lights SHOULD NOT come up when you turn the **** to Parking Lights which is the first one from the left...or middle one.
Its not normal.
Ya the only way the headlight should pop up in the middle pasition is if you have a problem with the headlight motor!!! mine was doing it untill i repalced the headlight motor!!
Originally Posted by ChicagoTransAm
Yep.. don't rig it. Replace your motor
You dont have to replace the whole motor when the gear strips. You can do the 180* mod and when it eventually strips again, replace the gear with a brass one.
