Turn Signal Issue....
The taillights and the blinkers are on the same circuit, so when any one of the taillights go out, it kinda fubars your blinkers too.
Kinda like the third brake light and cruise control are all on one circuit, same type of deal. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
When at night thouhg and the lights are on, I can manually do it, and the blinker will work, only if I click it though, the hazards also work fine...
Any ideas?
Sometime when it's dark outside, have someone else get in your car and start it up, while you stand behind it and watch your taillights. Odds are, one or more of your taillights will be dim, or maybe even out. Next, have the person in the car push on the brakes. Check for bulbs that are dim or not on at all with the brakes on. If you find any that are dim or out in either case, those are the bulbs and sockets you need to check out. On my old TA, by the time I figured out what was causing my blinker problems, I had three bad sockets that I had to replace. Replaced them, and my blinkers worked again. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
