Weird stereo/windows problem (don't think it's the bcm)
Alright I'm getting pissed... This has been going on for a few months now. It started with the Radio/Windows cutting out randomly. But if I gave the dash a light smack above the radio is would work again. Now last week another little goof has started. My interior lights don't come on if I open my drivers door and the Accessory power stays on like I didn't close the door. So I took apart the BCM yesterday and It looked perfect! No burn marks on the board or anything. So now I'm stumped! Anyone have any Ideas?
hey man i'm having a problem two with my driver window...it will roll down but to roll it up i have to play with it..it will go up an inch and than stop and have to keep hitting..is the motor bad or just a short in it? i called gm the motor is about $160..any suggestions???
Its the RAP system (module or whatever you call it that gives you the ablility to listen to the radio and roll up the windows when you have the car off for 10 minutes (Retained Accessories) . A lot of people are having a problem with this, but I havent seen any way to fix it, besides maybe replacing the RAP system, if thats possible? Mine has been acting up for a month now, off and on, usually when its hot outside. Now I put a new Headunit in and its worse...Hopefully someone will solve this dilema. Its really embarrasing when your bumpin your **** and all of a sudden the radio just shuts off. Ha
-Philip
-Philip
The RAP system is controlled by the BCM - there is no separate controller. The BCM is a black box about the size of a paperback under the dash on the right side behind the glovebox. Looking at it won't tell you a thing - it could be completely dead and still look brand new.
guys, check your grounds too. There are 2 grounding points at the dash, one behind each kickpanel, near the bottom of the dash. If one of those works it's way loose, all sorts of weird stuff happens.
also, for those looking at swapping BCM's, make sure you research that issue before buying one from a junk car. I'm not sure what years are compatible with others, and also, your key's resistor value for VATS is stored in the BCM. I think you can only program your key into a brand new, never used BCM. Once a BCM had been used with a key, I think it's locked in. Again, I'm not 100% on this, so do some research before spending money on another BCM.
mike
mike
Yes, you're right Mike. A BCM can only be programmed once for the VATS system. If you install a used BCM you have only a one-in-fifteen chance of getting one with the same resistor value. Otherwise, you'll have to install a VATS bypass kit to be able to start the car.
There were only two different BCMs used in 98-02 F-bodies - one with the factory alarm and one without.
ok so you think its my BCM, all of a sudden when im driving my stereo shuts off and my windows dont work, but if i hit the top of the monsoon deck it sometimes comes back on, or at least try to the antenna will come up and go directly back down, could this be the grounds. or is it definetely the BCM. also my hatch button stopped working on my key fob could this be controlled by the BCM also
The radio and power windows ground at G200 which is a bolt behind the kick panel under the driver's side of the dash. You'll find a stud with a nut holding a ring terminal on the end of a black wire.
exactly. While doing my alarm a few years ago, i noticed that this ground was not a good ground from the factory, it had some paint on it (wasn't bare metal). I just took the dremmel, and cleaned it up a bit. Your car may be simialr to this. I have never had a proble like this though.
I have a 1997 camaro convertible 3.8 V6 and it has the same problem where you have to hit by the radio to get it to work. Since this thread is from 2006 and this is now 2011, what are my best options if I want to swap the bcm? Thank You
